- Thread Starter
- #121
mdsimon2, what is the latency when you capture PCM through your hifiberry? I ask beacuse I would be capturing the analogue output from my preamp to do dsp on de PI while sending the rest of the signal straight to the amp. Another DSP would be processing the signal before the preamp thou, to accommodate for the delay to the subs, but still, this should be kept to a minimum and I find a delay annoying when changing tracks frequently.
Yo do flac streaming to minimize Wifi BW or what is the reason?
Are you talking about the HifiBerry ADC that I was discussing with @MarcosCh here -> https://www.audiosciencereview.com/.../rpi4-camilladsp-tutorial.29656/post-1094572? If so the 4-5 second delay is due to the WaveInput plugin in LMS not something inherent to the HifiBerry ADC. And yes, I use FLAC to minimize wifi bandwidth without losing any quality.
If you are talking about the Hifiberry Digi+ I/O I made some measurements here -> https://www.audiosciencereview.com/...tu-m4-phenomal-dsp-streamer.24493/post-930811, as mentioned above delay will depend on sample rate, chunk size and whether resampling is enabled.
I don't think what you describe will work well as there will be a 25+ ms delay between your DSP'd signal and the signal that goes straight to your amplifier.
Michael
