tjcinnamon
- Joined
- Mar 20, 2021
- Messages
- 238
- Likes
- 80
Hi All,
I'm in the process of analyzing my room. I'm looking to see if there would be value in moving around my existing treatments as well as buying new ones.
I have a few constraints:
- Speakers can't be moved due to in-wall speakers and a mounted TV
- The existing GIK "Alpha" Panels are advertised as being diffusion/absorption. In my experience they are not, they are very diffusive and are very absorbent
- The side walls can't have absorption due to then killing the Polk SDA effect (I've tried a number of options there). However, hard diffusion or membrane traps could work on those walls.
- I'm open to moving a bunch of treatments around but have experimented and absorption pretty much diminishes the SDA effect.
- I have subs directly behind the couch for effect. I can level them out pretty good but did not for the attached REW measurements (REW file is zipped)
