I have tried playing with mini dsps 2x4HD FIR filtering and it simply doesnt have adequate taps and resolution. The filter shape goes all over the place without adequate TAPs.Yes, 2x4HD has 4096 taps. What do you mean when you said you didn't like what it said the result would be? You couldn't get the curve right playing with those EQ sliders?
When designing my DSP speakers I did not find any off the shelf DSP solution which was adequately powerful, hence ended up with the XOs being performed on a PC with full Acourate software.
Watch out for the 2x4HD resampling, its poor with lots of low level spuria. There is a thread here somewhere on it.I guess the real question here with miniDSP 2x4HD is if upgrading it to DDRC-24, which costs $200, to be able to use Dirac Live is worthwhile. So, what's the verdict from you who are using Dirac Live?
What are XOs?
Sorry, crossovers
I see. Do you think Dirac Live would do better with DDRC-24?
Is this that thread?
https://audiosciencereview.com/forum/index.php?threads/measurements-of-minidsp-2x4hd.2459/
I have used the PC version of DIRAC and it was probably the best "off the shelf" auto EQ I have found, wees all over audyssey.
From memory it uses a proprietary mixture of FIR and IIR filtering to minimise latency and processing requirements.
edit
https://www.dirac.com/live-home-professional-audio-info
https://static1.squarespace.com/static/55c8a274e4b09cb562cd3ea0/t/57d159a69de4bbd9d306ac8f/1473337780806/Dirac+Room+Correction+(Audio+Engineering+Society,+AES+Sweden+lecture).pdf
Oh I think it will work fine, Im sure Dirac wouldnt license it if the hardware wasnt capable, I should probably temper my comments above to make it clear I was talking about full blown FIR filtering and crossovers.Good to hear! So how do you think DIRAC Live would work with DDRC-24?
Why would you want such huge corrections at those 4 points?
Are you sure you wouldn't have enough taps to cover the correction in 45-55Hz range? That would be odd as that's really a narrow range..
The Red lines show the output the FIR filter can produce given the restraints of sample rate and number of taps, given the requested change (Blue lines).
It's a narrow range of frequencies, but the wavelength (in samples) of those frequencies exceeds the available filter length (Like "working memory" in taps), so the hardware is incapable of fully supporting an FIR filter at those frequencies (my guesstimation).
For low frequency adjustments with limited DSP power, IIR (Infinite Impulse Response) filters are used. They (somehow) feed back on themselves as the stream progresses to calculate the next output sample.
FIR analyzes and adjusts the next output sample by looking at a "chunk" of samples, limited by the number of taps (sample holders). Fewer taps = less ability to work with lower frequencies.
There are experts here that can explain properly, but this is my meager understanding.
IIRC, FIR filter length is inversely proportional to the transition-band width and the depth of the stop-band.
i.e. narrower, deeper filters require more taps.
