FYI I posted this elsewhere but sharing here for those interested. Included the balanced of the ADI-2 Pro. As usual the manual is awesome.
How did you get it that cheap?Hi all. I'm new to the forum but have been reading lots. I have just purchased the RME ADI Dac2 FS based on great info both here and elsewhere. Bargain too. £749/800€. Looking forward to it replacing my Chord Mojo and will be listening via Macbook Pro/Roon to Focal Stellia.
Ah so that would be £864 with VAT. I got mine for £836 from Scan.It has been permanently for 720 pounds / 810 euros / 982 usd (excl. VAT) on Nord. Got mine from them.
https://www.nordacoustics.co.uk/product-page/rme-adi-2-dac
What settings are recommended to get the best sound with headphones.
I definitely think there’s an issue with my unit. The music is stuttering randomly and when playing music I have to have it pretty high and when watching films from Netflix and what’s already on my device I can’t get it loud enough at all.
If you describe your full audio chain from the source to the transducers someone here might be able to help you troubleshoot your issue. It’s more likely to be an issue with set up than a faulty unit (though that is always a possibility).I definitely think there’s an issue with my unit. The music is stuttering randomly and when playing music I have to have it pretty high and when watching films from Netflix and what’s already on my device I can’t get it loud enough at all.
I’m using an iPhone 11 Pro with the camera connection adapter connected to the DAC with the included USB cable. I’m using Qobuz for music and the Netflix app. I’m using the Beyerdynamic Amiron homes headphones connected to the phones output. The volume on the iPhone cannot be adjusted which the manual says is supposed to happen. I have the volume at -18 dBr.
The state overview says USB Sync:conn SR:96 State:2/2.
I think the DAC. It won’t let me change it as it’s grey.What is the clock source?
Yes it’s INT.Is it 'INT'? That is the DAC's internal clock.
Yes it’s INT.
I have an IPhone 12 Pro that I can try. I don’t have any other devices. When it switches from low to high power it does stutter but it also happens when the phone automatically locks itself and also randomly during music playback. Is it normal to have to set it to -18dBr for it to be loud enough?Do you have any other digital sources you could try?
Also, based on a previous post of yours, is this affected by you changing the volume? There is a relay being switched between low and high power mode which introduces something that could be described as a stutter during playback.
