RME ADI-2 FS Version 2 DAC and Headphone Amp Review
Matias
São Paulo, Brazil
FYI I posted this elsewhere but sharing here for those interested. Included the balanced of the ADI-2 Pro. As usual the manual is awesome.
AlfieFroud
Hi all. I'm new to the forum but have been reading lots. I have just purchased the RME ADI Dac2 FS based on great info both here and elsewhere. Bargain too. £749/800€. Looking forward to it replacing my Chord Mojo and will be listening via Macbook Pro/Roon to Focal Stellia.
How did you get it that cheap?
Matias
São Paulo, Brazil
AlfieFroud
Okay this DAC sounds amazing! What settings are recommended to get the best sound with headphones. I plan on giving the manual a good read but I’m not clued up on the technical jargon.
I do have a couple of questions. When using auto reference level the music stutters for a second when turning up the volume to when it switches to high powered mode, is this normal?
when using my Beyerdynamic Amiron home I’m finding I need to have the headphones at -18 to get a decent volume. Am I doing something wrong? I’ve tried looking in the manual and had a fiddle with the settings but can’t seem to find anything.
Phorize
U.K
Are you importing it into the U.K?
Phorize
U.K
Zensō
California
AlfieFroud
I definitely think there’s an issue with my unit. The music is stuttering randomly and when playing music I have to have it pretty high and when watching films from Netflix and what’s already on my device I can’t get it loud enough at all.
JIW
Germany
What input are you using? Have you checked the 'State Overview' (see page 30 in the manual)?
What is your volume setting - both on the DAC and the digital source?
Have you tried any other DACs or, if available, the built in analog output of your digital source?
Zensō
California
If you describe your full audio chain from the source to the transducers someone here might be able to help you troubleshoot your issue. It’s more likely to be an issue with set up than a faulty unit (though that is always a possibility).
AlfieFroud
I’m using an iPhone 11 Pro with the camera connection adapter connected to the DAC with the included USB cable. I’m using Qobuz for music and the Netflix app. I’m using the Beyerdynamic Amiron homes headphones connected to the phones output. The volume on the iPhone cannot be adjusted which the manual says is supposed to happen. I have the volume at -18 dBr.
The state overview says USB Sync:conn SR:96 State:2/2.
JIW
Germany
What is the clock source?
JIW
Germany
Yes it’s INT.
Do you have any other digital sources you could try?
Also, based on a previous post of yours, is this affected by you changing the volume? There is a relay being switched between low and high power mode which introduces something that could be described as a stutter during playback.
AlfieFroud
I have an IPhone 12 Pro that I can try. I don’t have any other devices. When it switches from low to high power it does stutter but it also happens when the phone automatically locks itself and also randomly during music playback. Is it normal to have to set it to -18dBr for it to be loud enough?
JIW
Germany
Regarding the relation between the stutter and the phone's behaviour, I don't have any good idea how to fix it. I would suggest you contact RME support or sign up to the RME user forum and if you are fortunate enough, maybe @MC_RME can help you here as well.
According to the manufacturer specifications -18 dBr should give about 110 dB peaks at 500 Hz. I would consider that quite loud even for very dynamical content.
At what volume setting do the headphones sound as loud as the iPhone on maximum volume?
