Electro engineering, actually, emeritus nowadaysHe claims to be an engineer (of what?) so that should be straight-forward for him to do, not that I think he'll do that anytime soon.
Maybe it's pseudo sibilance.. as in pseudo science.Perhaps you should read more about proper audibility testing here, on ASR, as that's not a subject covered by any EE program. Differences that you are describing as "not subtle" are impossible with the differences between HQP and RME built-in filters. Like sibilance, for example.
Wonder, is there any tests performed here using HQPlayer software re-sampling and filtering? As the RME provides in my ears the superior setting Direct DSD, hence bypassing internal DSP, it allows for expernal dsp and HQP is changing this DAC from being an OK DAC to an awesome one.
Try playing music using RME's Direct DSD, HQPlayer setting ADSM7ECv2, poly-sinc-xla, DSD256 over PCM, (etc). Is is mind-blowing and highly addictive.
I know, it took a while until finding a AKM4493 v2. I had the v1 first, but when finding the v2, I sold it back to my brother who was *drums* blown away when he heard the HQP stream with bypass on v1 at my home, compared to when he first owned it. He is likely as stupid as me, as it seems ...But only the AKM version lets you bypass the modulators. The ESS version won't let U do that.
But I agree. HQPlayer allows for some nice improvements.
@MC_RME?Please also note that Slow and NOS filters cause much more aliasing into the audio band and out-of-band noise than Sharp filters.
You're describing a phenomenon that should be absolutely and undoubtedly measurable.The difference is not subtle at all, there is in some cases a massive impact. I have had the pleasure of meeting some of the persons with whom I'd disussed this topic with and listened to their hifi rigs, and the common denominator has been lack of silence. The total level of noise produced in those rigs, for various reasons has been clearly audible
Please don't go that road.This is the danger with an all tech approach, the trust in measurements as the only way to tell the truth?
There's absolutely no way that this wouldn't be measurable. Noise (like with silence dithered test file) is extremely easy to measure. Just like this:lack of silence. The total level of noise produced in those rigs, for various reasons has been clearly audible
Then, instead of annecdotes, please bring actual proofs (controlled listening). There's none out there, showing that two DACs measuring well below threshold of hearing, would not sound the same. Just none.Well they don't and I bet you also recognize a difference, even though the measurements look almost exactly the same.
I assume the tests here are done in a perfectly controlled invironment, I would guess a sealed/shielded laboratory room, where any interference, wired or airborne is null, mains irregularities is filtered out, to exclude all this from the equation?
Please continue this in the following thread:Then, if there is anyone, that have the RME DAC, the measurement rig, and a room for laborations? I assume the tests here are done in a perfectly controlled invironment, I would guess a sealed/shielded laboratory room, where any interference, wired or airborne is null, mains irregularities is filtered out, to exclude all this from the equation? Just the sheer challenge I would assume to be a trigger for any major contributor here? No need to do it for me, though, but maybe some other owner of the RME DAC with AKM chip that do not trust their ears will be grateful for the insight it will not be necessary to replace the DAC for years to come.
You are right, I just need enough time in my hands to do all what has to be done...I asked because in your ESS graph, linear phase filters are not quite linear. So I’m curious to see if it’s the same for the AKM version, and I thought you would double check that and double check the graph already posted.
RCA is susceptible to Ground loop noise, so if you have that, then switching to XLR and breaking the loop would absolutely be audible.Do you think the difference is audible between RME RCA out to a quality amplifier as opposed to XLR out to a quality amplifier?
Balanced output is 6 dB higher.Do you think the difference is audible between RME RCA out to a quality amplifier as opposed to XLR out to a quality amplifier?
