Yes, you are right. I have to extract some logs.
I am gonna try that also.You may also want to try playing music via some local player in order to test basic audio functionality without roon bridge.
But i have this "ROON infrastructure" already in place and i am very happy with it.
I will try another OS, like Ubuntu or Armbian.
Yes, maybe MPD or something.I meant to try that just for testing.
There are not so many OS-es for NEO2.
Tank you. I will try it.I don't use Roon, but I tested it. It worked. Here are my OS images
https://github.com/bz31/Buildroot/wiki
Could you please recompile another one including the script for OLED?You are right. Indeed I have compiled a minimal OS image.
I can try to recompile another one if the current OS image (the one for roonbridge?) works already for you.
Could you please test it ? It seems that this image may not work depending on network configuration (dhcp problem).
Thank you.I can try to recompile another one if the current OS image (the one for roonbridge?) works already for you.
Do you think a normal Raspberry Pi will measure that good as well? I've read somewhere that it shares usb and ethernet on the same bus so it could be noisy. I have a RP 3 so not the latest.
It will not be noisy but it will suffer from occasional dropouts. It worked fine for me with Volumio but it started to make problems when I activated brutefir.
With I2S DACs it works perfectly well.
Brutefir certainly does something that triggers the dropouts, unless you pin it to a single cpu core. I gather there's something else that's often running on Volumio that triggers it too, but I forget what (database?). I've not had dropouts on PiCorePlayer despite trying to trigger them. Not tried with RoPieee.It will not be noisy but it will suffer from occasional dropouts. It worked fine for me with Volumio but it started to make problems when I activated brutefir.
Correct - the dropouts are a USB thing.With I2S DACs it works perfectly well.
