somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 3,759
- Likes
- 3,064
What's your build process for the image?
BR2_TARGET_ROOTFS_INITRAMFS:
Integrate the root filesystem generated by Buildroot as an
initramfs inside the kernel image. This integration will
take place automatically.
When you login to the Neo3 and run `aplay -l`, what do you see? Does this show you the right DAC.Hi folks,
Need some ASR brain power. I just received Neo3 install dietpi and GMediaRender. Dietpi shows up on my network and as an end point from my media app. But it won't play. I start a song and it stops almost immediately. Do I have to do anything with the USB to get it to output audio?
Some steps would be really helpful.
Looks like your USB interface is card 1, so show this:root@DietPi:~# alsamixer
cannot open mixer: No such file or directory
I suspect that you may have to tell GMRenderer which card to use. This doc has some tips:It seems be correct.
│ Card: D30 Pro F1: Help │
│ Chip: USB Mixer F2: System information │
│ View: F3:[Playback] F4: Capture F5: All F6: Select sound card │
│ Item: D30 Pro [dB gain: 0.00]
grep -Frl gstout-audiodevice /etc
If all of that is too much of a pain, you can use my trial code to start a Roon subscription. ;-)I suspect that you may have to tell GMRenderer which card to use. This doc has some tips:
gmrender-resurrect/INSTALL.md at master · hzeller/gmrender-resurrect
Resource efficient UPnP/DLNA renderer, optimal for Raspberry Pi, CuBox or a general MediaServer. Fork of GMediaRenderer to add some features to make it usable. - hzeller/gmrender-resurrectgithub.com
Essentially, use "aplay -L" (upper-case "L") to get the name of the device…it may not be "sysdefault".
You'll need to track down the script that is starting the process and possibly change the device to match your audio interface. This command may be useful to help you identify which file to edit:
Code:grep -Frl gstout-audiodevice /etc
Hi,If all of that is too much of a pain, you can use my trial code to start a Roon subscription. ;-)
I have a NanoPi NEO2, and it makes a very nice little Roon endpoint.
