Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
24-bit and full volume achieves the same thing though, remaining bits are zero'd, but also supports 24-bit audio if your source is higher-res than 16-bit players like foobar2000 and Roon also use 32-bit volume control before the output gets sent out, so again 24- or higher output rate is simply better.If you use wasapi, asio or kernel streaming and bypass windows k-mixer/resampler it will also bypass windows volume regulation. Nevertheless, you shouldn't use windows volume regulation at all if you are purist guy and have it always set to max volume in windows as it kills dynamics as you said. Of course your trick can do the job a bit but it's better to use volume regulation that comes from inside the dac (like in ess on very long word - 48bit if I recall, so there is no impact on dynamics) or your headphone amp in the unit. I am using windows volume set to max, always, thus 16 bit & 44,1k in windows.
Finally, 16-bit audio usually scores much lower in Jitter tests. There is no downside to 24-bit, even if you want to max out volume on the DAC at all times.
