We must to have almost zero output impedance until at 100Mhz.
"We must have" is not an answer, you should explain why.
Why would you need 100MHz when DAC chip doesn't output frequencies even remotely close to that? Not to mention that in the next stage after I/V you'll do low pass filtering to block alias frequencies..
And why "almost zero output impedance" when you will have output buffer to lower impedance - which btw is again OPA2134 in D10? Speaking of that, are you familiar that Amir did try rolling the op amps in place of output buffer in D10 and OPA1612 didn't perform any better than OPA2134?
