digicidal
I could go on, but the bottom line is that lab quality results require special measures to be taken to reduce variables such as power irregularities. Why? Because when you're measuring down to as low as -122 dB (which IIRC is one of the better readings that Amir captured in his testing), it doesn't take much to throw readings off.
I agree with that in principle, however with the noise floor of the APx555 still being a good 20-30dB below that level I think there's little problem. The thing to keep an eye out for is when the low-side results become buried... as that would indicate that either the measuring floor has risen or that the testing level has dropped to a point where more accurate devices would be required to provide accurate measurements.
It would be interesting (to me at least) to see if a pure-sine conditioner/generator would make any difference - however, I believe that @amirm stated in the "introduction to my new gear" post that the baseline values were nearly identical to AP's specifications so I very strongly doubt it would matter. That might be an overly simplistic view, but I'm not an EE so this definitely isn't an authoritative response on my part - but it makes sense to me at least. I know I didn't see even the tiniest ripple around 60Hz in those tests (looped AP-AP graphs)... so I think power issues are a null factor.
Edit = I'd say until we have DAC's hitting down in the area between the yellow lines... there's no reason to go "snipe hunting" for that last remaining .0001% of capability.
