Anxiety and audiofoolery are definitely linked.
It means human's behind. As in not good. Very childish and unprofessional language he is using as a member of industry.I'm not sure what he means by assy.
There’s only one way to settle this..,It means human's behind. As in not good. Very childish and unprofessional language he is using as a member of industry.
The 'brilliant' company name they came up with was, after all, Schiit... I would think they have a big white suggestions board covered in every puerile, scatalogical name they could think of. I surprised they haven't used Asswhole, Sphingta, Pyle or Stayn yet, maybe they can be next year's names. If so I want a cut for naming them here, first.
Pyle used to make some rather serious car amplifiers and subwoofers, IIRC back in the day.
I recall Pyle was quite popular for car audio in the late 80s/early 90s, for the first reason stated above. I don't have any experience with their current offerings, but I did notice that they publish T-S small signal parameters in their PDF manuals on the page following the template.They quite recently made some ok PA drivers and horns, have never used their stuff but from what I understand they did some good value for money parts. Their previous line of horns were good, although mostly copied out of production designs from other manufacturers iirc. Had a brief look at their new product lines and didn’t get the impression they were going in a good direction however - the horns don’t seem to make acoustic sense and they’re not even publishing TS parameters on their current woofers it seems.
Putting aside the unprofessional language and focusing on technical detail, I don't know what he is saying about the power supply. Here is the Modi 3 with USB power and no external power supply:
As you see, the output remains the same at essentially 2 volts. No external power supply is needed which makes sense given the fact that USB provides 5 volts.
Ok but then he was answering the wrong question. People were asking why he had gone from external linear power supply to a switching one. I thought that is what he was answering. Clearly he was not.I see what he's saying. To get low distortion 2V RMS output DC coupled you need a bipolar supply, at least +- 5V rails. You won't get that from 5V DC in without a switcher.
I surprised they haven't used Asswhole, Sphingta, Pyle or Stayn yet, maybe they can be next year's names. If so, I want a cut for naming them here, first.
you should ALWAYS take the worst channel measured as the true measurement of the dac!!
also nothing worst than bad channel matching..
it's funny how people post measurements and after they take the best channel measured when the other one is 7-10db higher in thd
and crosstalk, square wav rendering should always be included in truthful measurements
I ran into an article recently where one of the central findings was the idea that a high-end DAC had poor low-level linearity as compared to a cheaper, more linear one, but that dynamic compression could be perceived as a sonic benefit by many listeners.I get a lot from seeing the test of a 1kHz impulse at -90.3 dB. First at 16 bit and overplayed with the test with 24 bit. Shows the change in noise floor.
The Modi 3 looks to deliver around 19 bits. Each 6 dB drop is one bit. This is great for a 100.00 dac.
The standard IMD test is always interesting. But should never occur listening to music.
To me the 16 bit analog output of the 1kHz tone at -90.3 dB is where the line is drawn between the men and boys. Should be three clean steps.
Some expensive dacs output garbage in this simple test. No low level linearity.
