- Thread Starter
- #121
I am starting to lose hope that they will answer. This is the only communication so far from the weekend:I'm really curious about their answer.
Their definition of "snappy" and mine vary quite a bit.
I get that frequently although the differential is usually pretty small (1 to 2 dB). For this reason I now average the two channels and divide by two for inclusion in my SINAD bar graphs.channel difference is SINAD is something new, usually the mismatch is in RMS levels.
Is it because the D30 power supply noise seems to have improved in this measurement? Is this with the linear power supply?This is a few db better than before. Not sure what explains it but as a way of comparison, is valid because everything is the same now.
No, it is with the supply that came with it.Is it because the D30 power supply noise seems to have improved in this measurement? Is this with the linear power supply?
Sorry, since I don't really understand this post I have some (maybe dumb) questions: Who is baldr? What forum is he in?
What is PTSD? And what is a "sterer" (there is no translation for that word into my German language)?
This quote is sarcasm, right? Or is it a joke? I'm a little confused...![]()
How important is all this below 96dB for 16 bit audio? I realize it's not too important, but is there any, even if tiny, benefit of say 110dB SINAD over 100dB for redbook material?
Going pretty low there on the PTSD. Pretty shameful calling PTSD in any form irrelevant even as a bad joke.
I see it the same way. And scientists, too. The human auditory system very probably cannot nearly compete with an audio analyzer. At least not consciously.
*There's no evidence it gets to the brain in the first place.
Maybe this is no evidence. It's deemed controversial, at any rate.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4005747/
Other hits:
https://www.google.com/search?q=ultrasonic+frequency+effect+on+brain
OK, thanks. But what has Amir got to do with PTSD?
I still can't believe what this person writes. If a founding member of Schiit writes stuff like that I don't understand why people buy products from that company (pardon Amir, I do not want to offend you).
At least I know now that I will never ever buy anything from Schiit (never had the intention anyway).
Some people don't care what type of attention they get as long as they get it I guess.
Eric
You were right so I did that yesterday after getting their answer:Maybe you should have sent them a direct link to this thread? Otherwise they may not take you serious enough.
I ran this response through google translate and the following came back..,You were right so I did that yesterday after getting their answer:
At least they are confirming that there are no ASIO drivers.
You were right on the money. Installing those drivers allows ASIO4ALL to run in 24 bit mode:They say the drivers they provide should work on Windows 10. Perhaps it'll work if ASIO4ALL uses their driver instead of Windows' UAC2 driver?
