Hi! I’m new here
Have the same amp bought also on ebay three weeks ago, for home teater and it sounds pretty good;can you teach me how to bild this trigger liked box to turn the unit on ad of trough the data port? I will very appreciate that;I have this like in the pic below used it for turn from sleep mode a Crown xls 2 and works very well; I think it is pretty much like that that you have bt I don’t know witch are the two pins on the Dataport to take.
Thanks
Thanks
A quick update. I want to thank Amir for testing this amp (yes it's mine). It is a used unit bought sight unseen on eBay and shipped directly to ASR. I replaced the fan with a Noctua NF-A8 fan connected through a 220 ohm, 2 watt series resistor; it is very quiet now. I also built an 12vdc relay box to control the DCA2422 power from the pre-amp 12v trigger out signal through the power amp DataPort. BTW, the inside of the box had a lot of dirty, large dust-bunnies that needed to be given a new home. I didn't use the speakON connectors but the available screw terminal for the speaker wire connection. The unit is functioning very well.
