The French test of the 2x350 watt Yamaha P3500s is here: https://www.homecinema-fr.com/forum...mpli-yamaha-p3500s-mise-a-jour-t30056383.html
As for trigger inputs, I faced a similar problem, because the on/off switch of my Quad 606-2 is on the back of the unit. It does not have a trigger input, nor does my ADI-2 have a trigger output. I am now successfully using a cheap master-slave power strip. It senses that I turn on the ADI-2, and then turns on (and off) a string of other units, including the power amp. The only issue was that the ADI's power consumption is too low for the master sensor, so I combined the ADI-2 with my always on Chromecast Audio because their joint power consumption is just enough for the master's sensor. It works a treat without complex modifications and for little money. A rough calculation showed me that it will earn itself back with a slightly reduced electricity bill in about a year. That is one more little step in reducing my energy footprint, even if in this case only a very little one.
