Does anyone else experience issues like shown in the following video:
https://vimeo.com/839104811?share=copy? This is while using a Pi4. At first i was using Roipee but Pavel said to try Volumio with the Roon plugin, but that one completely failed to play anything beyond some initial loud buzzing through all 5 connected channels (screenshot attached). Trying to get a sense of whether it truly is a faulty unit or if these are common problems. I gave up on using a MicroRendu with similar issues, and thought the Pi would be a safer bet. I also use a VanityPro via AES that will only play PCM files reliably (cannot send DSD over DOP to the Okto without getting flashing channels and buzzing). At this point the only reliable way i can play music is by hooking up my large Mac Pro and playing PCM via USB, or playing discs outputting PCM into the VanityPro. I can't use the Pi via USB at all.
Yes same here. Volume won't do anything. I doubt it is an issue related to the RPi. It works fine with other DACs. It turned worse with the FW-Update because of the display thing. Disabling the display reduced the noise and of course I do not see any flickering anymore... I hope for a hardware fix.
