I'm planning on ordering a D50s but have read that the D50 sounds cold and analytical. If you have one, does it sound this way to you? Thanks.
As long as the DAC is true to source, analytical is fine. You can pair it with a tube amp/pre-amp to add some colouration and depth. Good tubes required though.I'm planning on ordering a D50s but have read that the D50 sounds cold and analytical. If you have one, does it sound this way to you? Thanks.
Just purchased burson playmate with v6 vivid and im planning to buy a good Dac to pair it with. And im thinking of topping d50s. Will topping D50s suffice? I think they both have the same dac chip the only difference is the dual dac of topping d50s as compared to a single dac chip of burson. With the dual dac of topping will there be great improvement in sound quality?
Thanks
Good afternoon.
I planned to buy a DX3Pro, but after reading reviews about unstable quality, at the last moment I bought D50s (not having studied its capabilities in such detail).
And as I see now - in the D50s there is no "only DAC" / "preamp" mode switching.
I use D50s in conjunction with a Denon pma-720ae amplifier. When the volume is set to 0dB on the DAC, the volume level is very large, on the amplifier the adjustment is sharp.
The question is - when the volume is reduced by means of the DAC, do I lose in sound quality?
Will a constant level of 0dB (2 Vrms) harm my amplifier? The amplifier does not have a preamp input, only 4 line inputs (+ phono corrector).
I am debating between buying the D50s and D50. The D50S is $50 more...I am kind of on the fence. I have Sony Bluetooth WH-1000XM3 headphones...will there be any improvement in sound quality if I connect to the Topping vs directly to my computer?
Also how is the quality of the silver finish?
But your headphones are wireless right? Don't buy all that for the Sony XM3 the internal circuitry is still digital, there's no point!I am thinking of Schitt Vali 2 or a solid state amp in the $200-$500 range.
I have HD600s and the Sony
