This is a review and detailed measurements of the brand new, Topping D50
s. Yes, this is a new revision of one of our favorite DACs, the D50. The new version brings Bluetooth, remote control and better performance (see measurements below). It was kindly sent to me by Topping. I don't see an announcement on it but Topping has shared with me that it will cost US $250. The unit I have is production version but lacks manual, stickers and such.
From the outside, the D50s looks pretty much the same as D50:
You can see the antenna in the back for Bluetooth. The remote control is the same as recently Topping offerings. Indeed I used the one from Topping DX3 Pro to control it. It uses two AAA batteries so there should not be any issue with coin cells.
The back panel is what you expect:
For my testing, I just used the round 5 volt cable to USB that Topping provided. I simply plugged that into one of my USB 2.0 on my desktop workstation.
I did not test the Bluetooth but seems like this is becoming a standard feature on DACs which is nice.
All the testing was with Windows 10 USB UAC2 class driver (i.e. I did NOT install anything).
DAC Audio Measurements
Let's fire up the dashboard to see what we have here:
Nice! Highest level distortion in the "bad" channel (FFT top right) is at -120 dB which is a few dB better than the best our hearing can do. Clock accuracy is right on the money with that 1.00000 kHz reading.
THD+N and hence SINAD (signal over noise and distortion) have improved by a few dB over D50. Given the small difference in SINAD between our top DACs, this moves the D50s good few notches towards the top of the class:
The D50s like D50 uses an ESS DAC where with some exceptions, we have been suffering from an "IMD ESS hum" where at mid-levels, intermodulation distortion suddenly rises. Guess what? Topping has fixed this!
Hurray!
I know what they fixed but I am not at liberty to say what. I will say that they had to fix this themselves and did not get help from other sources.
While we are on this graph, a trend seems to be merging between DACs based on AKM and ESS chips. AKM DACs seem to be more quiet as you can see from performance of DX3 Pro in red. But at max level though, ESS DACs seem to have less distortion by a few dB. Interesting trade off.
Dynamic range reflects the above:
This is about 7 dB worse than
Topping D70 with is based on AKM chip. Yet, the D50s beats the SINAD of the D70 by 3 or 4 dBs.
Frequency response depends on filter setting. Here it is using the default (mode 2) filter:
Nothing really eventful. Here are the filter differences:
You have the classic choices here of wider bandwidth but less attenuation of out of band aliasing and vice versa.
Jitter visually looks clutter because of low noise floor revealing smallest aberrations but not remotely an audible concern:
Linearity is nailed as one would expect from a well engineered product:
Testing with 32 tones rather than one or two, we see exceedingly low intermodulation distortion:
As noted, the difference between our tone peaks and the distortion floor is better than 120 dB. This is transparency in play.
One of our favorite DACs has grown up and become even better. The D50s solidly eliminates the ESS IMD hump, adds the much needed remote control and Bluetooth without a premium in pricing. It makes great pairing with such headphone amplifiers at
JDS Labs Atom being roughly equal in size and looks.
It is a pleasure to see Topping continue to deliver well-engineered audio products without exception. Using proper measurements allows them to verify and refine the design before we get our hands on.
Needless to say, I am happy to recommend the Topping D50s.
Questions, comments, critique, etc. are welcome.
Avid readers of the forum may have noticed that the left ear on this pink panther no longer looks chipped. Sadly, that is repaired in photoshop. The poor little panther has been pleading with me for an ear transplant but I just can't afford it. Please donate some money toward that cause so I don't have to keep putting injured animals to work using:
Patreon:
https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (
https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
