Yes gain on high too. Even without these modes on E10 has always sounded more fun to me.Did you have your bass mode on E10?
that would play a big factor.Did you have your bass mode on E10?
Looks like line-out dynamic range is on the order of 106 dB or so, which would only be good for so-so output noise levels when connected to a 29 dB power amplifier... not terrible but merely run of the mill receiver level. When using sensitive speakers, dynamic range requirements may noticeably exceed 120 dB if noise is to be kept inaudible.Hello, I have a question about fiio K5 pro connection. Can I use it as pre-amp to connect a power amp? I saw on fiio FAQ that this way of connection is not recommended, so I would like to learn the reason behind this. thx!
YT Music may not work with those settings. YT audio is basic.Should i use 24bit 41khz or 32bit 41khz?
What are the advantages of 32-bit? (I've never seen audio files created with 32bit)
I mainly listen to spotify, youtube, twitch and some flac files that I have in my collection
I don't use YouTube music; regular youtube videos play smoothly with 32bit 44.1khz.YT Music may not work with those settings. YT audio is basic.
Never assume just try the K5 PRO's line-out. It likely suffices and give good results.So... Is it worth trying to run the line-out (pre-amp) from the K5 Pro to my new amp when it gets here? Or should I just assume that I will need/want a separate DAC and order one now?
What clicks?Hi to all i have a question for my K5pro.
Turning the volume knob while listening a song i can hear a clicking noise is this normal?
For example listening this songThe first 10 seconds its very obvious turning the volume knob i can hear these clicks .
I have many other dac amps with analogue volume knob and i dont hear these clicks.
Thanks a lot.
It reminds me some very old amps that when u turn the volume knob it scrathes like the noise u get from dust record's .What clicks?
Don't worry. I got it. It still happens with my FiiO E10 and it has been working fine since 7 years.It reminds me some very old amps that when u turn the volume knob it scrathes like the noise u get from dust record's .
Sory i cant explain it better.
It stops when i dont turn the knob and its low noise not something u can hear when the song is loud.
Thanks for replying.
If its not a problem then i am ok with it.Don't worry. I got it. It still happens with my FiiO E10 and it has been working fine since 7 years.
Merry Christmas.If its not a problem then i am ok with it.
Does fiio use something different on their potentiometer knobs ?
Ps. I have make this question in so many forums and u are the only one answering very kind of u have a great Christmas.
For the price, the power output it is not too bad. Not a state of the art performance, but not too bad. It's probably fine for a lot of people. I agree that one doesn't need to be too alarmist about lower SINAD since overall, especially power-wise, it performs OK.
Amplification-wise overall it does good. To use as a DAC in line-out it is a bad purchase, but for an all in one headphone amp it would do well enough.
Other way around: to buy K5 Pro as an amp to use with line-in from other DAC servers little point, there's no advantage there.If I understood this right, are you saying that line out to another external amplifier is a bad idea ? If so that bums me because that is exactly what I am trying to do.
To use it as a line-out to something else is just fine.
You could try 1V out and higher volume on the amp that could work quite well, but honestly you might not notice any difference compared to 2V out in terms of fidelity.. it's likely "fine". I'm not into tube amps though, such as the Little Dot, so I can't provide any real-world anecdotal experience there.Thanks for your reply. My concern is that the test result showed that the SINAD from its LINE-OUT port showed 82dB with 2V. My understanding is that RCA line-out usually would have to have 2V as a feed to another device. If I turn down volume on the knob to adjust the voltage to 1V then it will achieve 98dB as per Fiio's claim on thread page 12. Would 1V then be too weak to feed to a Little Dot MK2 that I am thinking of purchasing ? Conversely, full volume would output 2V but I am afraid of audible noise that may result (on top of the fact that tube amp itself loses details).
Thank you very much for your input! (Pun intended)You could try 1V out and higher volume on the amp that could work quite well, but honestly you might not notice any difference compared to 2V out in terms of fidelity.. it's likely "fine". I'm not into tube amps though, such as the Little Dot, so I can't provide any real-world anecdotal experience there.
