Review and Measurements of Chord Mojo DAC and Amp
pkane
North-East
-200dB is not enough ! See:
:D
I see Rob’s hearing has improved over a few years from -200 to -301dB!
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
He's giving reports to NASA on how the mirror stepper motors on Webb are sounding.
Music1969
Miska
But still has fairly low stop-band attenuation on his filters, ranging from 100 to 120 dB. Thus giving about 17 - 20 bits reconstruction accuracy from digital filter point of view.
For Mojo2 I wonder if he has got around to fix the flaky USB interface implementation. With my first gen Mojo I get full volume white noise blasts after a while with any source device. Happens due to USB packet loss and that drives rest of the pipe nuts. Really nasty with headphones...
Jimbob54
SRKRAM
Almost as hilarious as Darko forbidding links to his site from here....
I wondered what was going on when, a few days before the mojo 2 launch, Darko announced that he wasn't going to cover DACs any more, at least for the rest of the year because they have less of an impact on the overall system sound. The article was accompanied by a picture of a mojo OG. I wondered if it was setting up for a review of the mojo 2 and then, sure enough, he comes out with a 'not a review' of the mojo 2 and an interview with Rob Watts.
Veri
So far in Mojo2 head-fi I saw multiple people having the white noise blasts. So I guess same sort of chance for it to happen..
Jimbob54
I love that Mr Watts takes his m scaler on plane journeys. Essentials!
seelphedvr
On that particular point, it is just the way the link was added. The link works perfectly fine once you remove the final "/". I might also be wrong but doing that solved it.
mudy
I think he block on http referer. When you click on a link your browser will send current webpage location to the new site. But when you changed something on address bar then enter again browser won’t send previous webpage again.
mansr
Hampshire
Yes, he does:
Code:
$ curl -I --referer https://audiosciencereview.com/ https://darko.audio/
HTTP/2 403
date: Thu, 24 Feb 2022 10:09:35 GMT
x-turbo-charged-by: LiteSpeed
cf-cache-status: DYNAMIC
expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=gJ5C2pL5pA9WCbE8B269HX%2BaKxmOxdYTzcGpQ1X5TzCJ0IFMOGPQxHnRvljr05mRfCxGRP9xA4Br4ZYxKxrMzU5apWflhelXdFVucAnSdwWbP%2F03Dw5szi8UxwjOh2SugdLRYIlFfiqWBg%3D%3D"}],"group":"cf-nel","max_age":604800}
nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
server: cloudflare
cf-ray: 6e27e63459ca892a-LHR
Very childish.
Jimbob54
Yes, he does:
Code:
HTTP/2 403
server: cloudflare
Very childish.
If they can't see me they can't hurt me!
Miska
You can use privacy proxies to strip referers. I do that on a Squid proxy using regexp rules, so I can decide to selectively do it.
Ken Tajalli
London UK
On my Mojo Classic, the only times the white noise happened was due to crappy cable.
Once I fixed that, it never happened again.
BTW, I am pretty sure that the USB input and its firmware was not his (edit: Rob Watts) doing .
I believe he mentioned that at some stage.
Bronco
I think you may have stumbled onto the next big thing here, Woody.
Please excuse me while I run out and grab a tank of liquid nitrogen. I’m going to cool my Mojo down to -270C and see if it improves my SINAD number.
Bronco
Not just the m scaler, but the also the Hugo 2 and the battery bank required to run all of it.
Can you imagine how many hours of body cavity searches he’d be subjected to by the TSA if he tried to drag all that stuff onto a plane in the U.S.? LOL.
Simon P
I contributed to this thread before. I just bought a used original Mojo.
To me, the Mojo sounds different to a DACmagic 100. Using a separate amp in both cases.
My conclusion remains: Time domain reconstruction performance makes a difference subjectively. I'm sure both are excellent in the frequency/phase domain. Don't know which is more accurate and to what. Not sure which I prefer overall, probably the Mojo. The DACmagic has more sense of pace and slam. It draws more attention to the frequency extremes subjectively and to stage width. The Mojo sounds warmer, more organic, more 'rounded' and 'together'. Less suspicion of added 'hash' or 'grain'. It seems to give more expressive vocals. For me. How much difference it makes to an individual I'm not sure, but I'm pretty certain there's a difference. Are my impressions valid? I have failed in the past to consistently identify hires files compared to CD res, blind, in quick comparisons! So I could obviously be wrong. But I still don't think so.
The minus 301 dB stuff did seem a bit far out to me. Maybe I don't understand what Rob is trying to say. I think he's discussing the error level at each tap in a FIR, which could accumulate. I don't think Darko is an in depth a technical guy.
