Maybe the beautiful insides biased lots of them![]()
Oh yes, internals are beautiful. So much components for so poor measurements... That's a shame...
Here are my internal pictures of R2R-2 DAC and NFB-28.38:
R2R-2:
NFB-28.38:
I do believe that Kingwa and Audio-gd could make good measuring products if they really want to, at least from their internal build quality, but they just strictly adhere to an ancient and basic principle (no negative feedback) that makes them measure terrible independent of their build quality.
Basically the Chinese version of Schiit... pushing obsolete tech for mythical reasons.I do believe that Kingwa and Audio-gd could make good measuring products if they really want to, at least from their internal build quality, but they just strictly adhere to an ancient and basic principle (no negative feedback) that makes them measure terrible independent of their build quality.
Yeah but @soekris knows what he's doing... look at the board layout. It's as good as RME internals, from a one man project.I disagree. Soekris' R2R boards have NFB. No feed back but still miles and miles better than whatever audio-gd outputs
https://www.audiosciencereview.com/...rements-of-soekris-dac1421-multibit-dac.3956/
From soekris:
The line output buffer is a high performance zero feedback design built with discrete parts, the buffer also have a high power mode to drive any set of Headphones. The main power supplies are ultra low loise, low impedance and very fast, also built with discrete parts.
From soekris:
From the measurements thread soekris himself saidIs there also no global or local feedback at any other stage in the Soekris DACs? Very interesting to see such an impressively low distortion figure if that is the case.
The output buffer is a zero feedback design so it add a little 2nd and 3rd harmonics at high levels, lower the level a couple of dB and they don't dominate anymore.... Still, they're way below what you can hear.
As for "at any other stage" I'm not entirely sure, maybe the man himself can elaborate@soekris
Correct, our line of audiophile DACs, the dac1321, dac1421 and dac1541, all have output amplifiers with no negative feedback at all. It's all about the implementation, with careful design you can make some simple and very linear amplifiers.... Our R-2R DAC core is voltage out, we don't need any Current to Voltage converters and can therefore do with just a single stage output amplifier. As you can see from our inside pictures, it still takes a lot of small transistors, but a lot of them are just constant current sources to make sure the active parts operate perfect....
If I ever were to buy a R2R dac, it would definitely be yours! Cheers
As was posed when the question was asked, is it likely that the Audio-gd units use a non-feedback design on areas that your DACs do not? I might be off base (I'm not familiar with the specifics of DAC design) but it is stated that your output stage is feedback-free, while audio-gd likes to say that there is no feedback in any stage of the design.
Yes and yes. Under blind listening conditions, people prefer high fidelity playback. This is true regardless of age, gender, cultural background, etc.- are measurements the ultimate guide on how good or bad a DAC / Amp sounds ? Would a dac / amp with the best measurements sound the best ?
That's an ongoing debate. I'm inclined to believe it's the high output impedance typically found in tube amps, which makes headphones with an impedance swing in the bass, such as the HD 650, sound muddier than they normally would be.- are "distortions" what makes the "tube sound" which a lot of people enjoy ?
Coming from a non audiophile like me ( i am not an electrical engineer, I just love listening to music ), may i ask
- are "distortions" what makes the "tube sound" which a lot of people enjoy ? I recently tried the Felix Audio Echo tube amp. I have read alot of people say that the HD6xx / 650 sound best with tubes. I found this to be true with the Echo tube amp.
I have the 11.28 and knew i was listening to some distortion...just been in denial..until now!Devastating.
