Have you removed the caps and accurately measured the dimensions? That needs to be done. You will need some isopropyl alcohol and a old toothbrush for cleaning. All that white glue/goo needs to be scraped off the PCB. Don't damage anything. Be gentle but firm and take your time. No rushing things.
For the isopropyl alcohol Walmart has 70% and 100% purity. If you buy 100% it is flammable and burns with a clear blue flame and that is dangerous. So maybe use 70%.
After the capacitors are removed then we can see what clearance we have to work with at the surface of the PCB so we don't contact any any other components. Be careful removing the caps and watch out acid fumes from any leakage the caps may have. Don't inhale that directly.
