Razer Phone Headphone Adapter Review
This is a review and detailed measurements of the Razer USB-C headphone adapter DAC and Amplifier for smartphones. It is on kind loan from a member. The Razer adapter sells for US $25 from company's website so more than twice as much as typical "dongle" from other phone companies.
The Razer adapter has sturdy build and is much larger than typical $9 dongle:
There is a THX logo on the other side of it. Nothing in the website indicates that that means. I guess we will find out in testing.
I measured the Razer dongle using Windows 10 which nicely recognized the unit as a DAC. Inserting and removing the headphone plug would cause it to be active or not.
There is no rise in temperature of the unit in testing I performed so power consumption should be low.
Headphone DAC & Amp Dongle Audio Measurements
As usual, we start with our dashboard of 1 kHz tone:
Sad to see the low output of just 1 volt as that will hurt available power into high impedance headphones/loads. SINAD which is a figure of merit for noise and distortion is just 78 dB which puts it firmly in the red category (worst quadrant) of all DACs tested:
While most dongles land in the same bucket, it would have been good for it to land higher in the tier.
Noise level is not bad:
RAZER PHONE AUDIO ADAPTER USB-C DAC Amp Dynamic Range Audio Measurements.png
Intermodulation distortion versus level shows what we know:
We are far away from any kind of desktop performance. If the output distortion did not rise at just -15 dB, it could have done much better though.
Using 32-tones to simulate "music" we see similar issues:
Jitter test is not pretty but then again, most dongles have similar issue (likely lack of filtering of the USB power):
Linearity test shows rather poor results indicating that we can't reproduce clean levels even below 16 bits:
Output impedance is a bit high as well:
Power Measurements
The most audible issue in any headphone amplifier is when it runs out of power and as a result, either sounds anemic, or very distorted. So let's measure that, first into 300 ohm load simulating high impedance headphones:
RAZER PHONE AUDIO ADAPTER USB-C DAC Amp Power into 300 Ohm Audio Measurements.png
There is no clipping but there is so little output power at just 3 milliwatts. As a perspective, I like to see 100 milliwatts in desktop headphone amplifiers.
Power does increase into 33 ohm as expected but still nothing to write home about:
RAZER PHONE AUDIO ADAPTER USB-C DAC Amp Power into 33 Ohm Audio Measurements.png
The higher output impedance is likely causing some losses here.
Comparing the power to other dongles we see:
Disappointing all around.
Headphone Listening Tests
I started testing on my PC first with Sennheiser HD-650 headphones. As expected, the volume was just not there. In a quiet room, you will have adequate loudness but otherwise, you need more power. Bass response suffered as a result fair bit as was low level detail.
Switching to Hifiman HE-400i, the situation improved and I had a reasonably enjoyable sound and performance.
Thinking I may be holding these little dongles to too high a standard, I connected the Razer to my Samsung S8+ smartphone. Here, performance was substantially better than using the headphone jack on the S8+. With the HD-650, the S8+ by itself was too quiet. The Razer increased volume by a factor of two or so and made the experience, "listenable." Likewise, the HE-400i really came to life with the Razer as opposed to S8+ by itself.
Given the larger size of the Razer dongle and THX logo, I expected to get a lot of power out of this device but did not remotely get there. So the thing you can hang your hat on is better build which does have value. As does the performance over native output of phones like my Samsung S8+. Net result is that you may still want to purchase this unit even though it doesn't perform that well. I am not going to recommend it however. I stand on too tall of a mountain to do so. :)
The panthers want to throw a huge party for the new year's and want to invite all of their friends. And that means one thing: tons of money spent on steaks to feed them all! So please help me with the expenses of this by donating generously using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
I recall reading that Razer had purchased THX, that could explain why their logo was on this product. Still, it’s a bit heartbreaking that you have THX 789 and 887, and then this.
I do wonder what happened to that thing... Whatever happened to its head (and forearm)?
He doesn't want me to tell the story because he is too modest. Between us then, he volunteered for a deep enemy mission overseas. Yes, they usually use dogs but in this case, the navy thought a pink panther would better blend in (the enemy looked liked pink flamingos and hence the reasoning). Anyway, they went there at 2:00am in the morning, got ambushed, and my beloved panther lost his head.
I heard the medic was amazed that he lost no blood, pink or otherwise! They gave me enough money to buy glue to put him back together. I thought the scarring would never heal so I have not gone there. I am looking for a skilled plastic/ceramic surgeon to do the job right. Until then, his head and his body are modeling independently and earning double income. In that regard, he is not too anxious to be put back together.
If you have this one, you could either use it for items that are an incredible value for the money (e.g. $100 or less, yet superbly performing) OR for items that are so ridiculously expensive, you have to raid every piggy bank around to pay for them haha!
@amirm Could you do a full set of measurements of your S8+ with your new analyzer? So in addition to your subjective impressions, we can get an objective, scientific comparison between a popular smartphone and these dongles. It would also be interesting to be able to directly compare the general purpose S8+ to the more niche, audio-focused LG G7 smartphone you've already measured. Thanks for all the work you've done!
His S8 is the snapdragon version though, while most of the world got the Exynos version.
I cannot unfortunately. My analyzer can't control my phone like it can with a dongle connected to a PC. So I can only run static tests and such. Its SINAD is in the graph by the way (89 dB).
Could you then post for your S8+ all the same measurements you made for the LG G7? That alone would be an interesting comparison.
Also, what music player, settings and volume did you use when measuring the SINAD of your S8+? As most music apps pass audio through the Android mixer which I believe resamples 44.1 to 48 kHz (as well as possibly degrading audio fidelity in other ways). There are two apps that are guaranteed capable of bit-perfect playback though, bypassing the Android mixer - Neutron Player (free 5-day trial here), and USB Audio Player Pro, so using one of these apps when taking measurements would be a much fairer comparison with the LG G7.
The entire US, Canada and China is a huge market for the Snapdragon variants. Plus, these versions have had higher quality audio output than the Exynos ones in recent years, as I've seen by measurements of the S9 and S10, the Snapdragon versions of both having the same audio chip as @amirm's S8+, so these are more relevant to an audio review site.
What measurements, done why whom?
This wasn't the case with the S8 afaik.
These measurements of the Exynos S9+ and the Snapdragon S9 by Soomal, and these (bottom of page) of the two variants of the S10+ by Anandtech. Have you seen measurements directly comparing the Snapdragon and Exynos S8 then?
Is this the same Razer company that owns the THX AAA tech ? Then how come they cant make a decent usbc dongle, they even dared put the THX log on it. The MEIZU Hifi Pro USB-C blows them out of the water and costs less if i am not mistaken..
THX razer snake oil. Poor george lucas and his once THX meant something now it is just become snake oil.
