piero.rossi
- Joined
- Jul 7, 2021
- Messages
- 8
- Likes
- 4
- Thread Starter
- #21
Hello all,
Few updates: a friend of mine gave me a DAC hat for free, since he doesn't need it anymore.
It is a PiFi DAC+.
I know this has been reviewed here, and got really bad scores; but there is also few post and a site that explain how to modify it to improve its SQ.
Actually it sports a PCM5122, so it should not be so bad.
I'm an electronic engineers, by other things, so I have a quite nice working bench at work; so, why not to try and improve it?
I made all the suggested modifications, moreover I replaced capacitors with ceramic ones (instead of those fake Wima), added few capacitors where I think they are needed (bypass and voltage doubler, as per datasheet and application notes); now the DAC sound quite honestly, to my uneducated (and old) ears.
There are also few engineering errors, like for example 33R resistors on the I2C and I2S buses; they should not be there, so I removed them.
Also the ground plane is not correctly implemented, so I modified it.
I also improved the (external) power supply, adding a lot of capacitance on the 5V rail, together with a few high-frequency filter.
There's no need for a linear PS, if you know how to filter out high frequency noise from a switching PS.
For the moment, I will use this DAC (it was free); my idea is however to move up to a better one, in the next future.
I still have to find the right configuration for the DAC in Moode; in particular, I will spend some time on the MPD's SOX settings, which are quite complicated, for me.
However, scope of this post is to let you know that a cheap DAC chip, if correctly implemented/updated, sounds quite nicely.
It is a PiFi DAC+.
