Hello all,
Im quite new to audio in general and need some basic help with a purchasing decision.
I have a set of Eve Audio SC204 speakers I purchased a while back. Im looking into connecting them to my PC.
Im ok to spend 400-500 eur for a DAC to connect them to my PC however im very confused in terms of what exactly to buy. Im saying this price as id like to buy something that will last me in terms of the quality of the components and features it provides. I will however be unlikely to tell the difference between a higher quality product and a medium one for example.
Ive narrowed It to needing a DAC and to Topping as they seem to have what I need (balanced output as better than unbalanced - not sure why but I know this ) )
However im confused as to which product I need from topping. Im not looking to drive them at max volumes for sure. Headphone amp built in is not a must as im not currently planning on investing in headphones but down the line who knows. Might get bit by the bug.
For example is the d70 pro sabre I need or will I be fine with a DX5 for example.
Thank you in advance.
