Hello,
I temporarily received a pair of KEF LS50 Metas at home to try out (I currently have a pair of Bowers & Wilkins 805 Nautilus).
The biggest difference I felt was the LS50's clarity and imaging capabilities (voices are clearly defined across the sound stage).
If this made sense to me before applying the EQ, it made me confused to occur after the EQ applied.
The frequency response of both speakers after EQ is almost the same, which does not justify this difference in sound perception.
On the KEF it looks like it is clearly in front of me, while on the the 805 (despite being in front of me) it looks more diffuse in comparison.
The big difference I saw between both in terms of measurements was the distortion. Although the 805 has lower values than the KEF up to 600hz, there is then a huge peak starting at 2khz up to 7khz (the crossover is at 3hz).
WITH EQ (KEF in red; B&W in green)
WITHOUT EQ
DISTORTION (should I change the measurement unit?)
Is this the main reason why I listen to what I described above?
And challenging a little more, will this situation disappear by changing the 805 cross-over?
BTW, i was not expecting the LS50 to go that low in bass after EQ.
Thank you!
