Nope. The question was: "IS DSD IMPORTANT, TRIVIAL, OR A WASTE in home audio?"The question was if DSD sounds better than PCM and not if multi channel is better than stereo.
I've stopped obsessing over DSD vs. PCM and simply choose my recordings on the basis of content, performance and sound quality. The formats are not significant to me as they are effectively interconvertible. If there are options, I try to pick one that is closest to the format used in mastering.However, there are recordings on 3+ channel SACD not available in other formats, so on that basis it’s worth having the playback capability.
Though I could easily imagine the situation where a stereo PCM master is screwed up and over compressed in all the multibit formats, but properly converted to DSD/SACD. I’ve come across the attitude that PCM is for streaming and DSD is for audiophiles in a few places online.I've stopped obsessing over DSD vs. PCM and simply choose my recordings on the basis of content, performance and sound quality. The formats are not significant to me as they are effectively interconvertible. If there are options, I try to pick one that is closest to the format used in mastering.
+1I've stopped obsessing over DSD vs. PCM and simply choose my recordings on the basis of content, performance and sound quality. The formats are not significant to me as they are effectively interconvertible.
In a properly set up comparison, the difference between the stereo and the 3-channel versions is significant. I have used that as a demonstration many times.I found around 25 multi-channel DSD discs in my collection. These range from remastered "Living Stereo" RCA Red Seal classical discs which are barely surround and actually sound quite good, but I am not sure there is much benefit from their being multi-channel.
I agree but, in general, I prefer realism to surrealism for my music.That said, I have to admit Pink Floyd's Dark Side of the Moon is pretty damned compelling in surround. As most here, I have heard this album innumerable times. The surround mix really works with this surrealist album.
I think I know what you mean. The Red Seal discs all seem to be 3.0 mixes and do sound open and spacious. As I mentioned earlier I do like these. I don't have the conventional stereo versions to compare, but I can see what's available via Qobuz or Tidal. It would be interesting to compare.In a properly set up comparison, the difference between the stereo and the 3-channel versions is significant. I have used that as a demonstration many times.
They are 3-track recordings, not mixes. The stereo content on the discs (and the original Living Stereo releases) are down-mixes from them.The Red Seal discs all seem to be 3.0 mixes and do sound open and spacious.
Thank you for the info! This totally makes sense.They are 3-track recordings, not mixes. The stereo content on the discs (and the original Living Stereo releases) are down-mixes from them.
Ok thank you Yearofthegoat, and please let us know if you find gap vs gapless for your Mch playback. For your set up, are you transcoding DSD->PCM with the HTPC (Foobar) and then sending Mch PCM over HDMI to an AVR, or do you have something different?I play multichannel DSD from a NAS using Foobar on an HTPC. Would have to check if it stays gapless. I think not (slight, tiny, pause), but I haven't fiddled with settings much.
That's it. I was hoping that my AVR (Yamaha RX-A3050) would take DSD over HDMI but it won't. Takes it fine off the disc of courseOk thank you Yearofthegoat, and please let us know if you find gap vs gapless for your Mch playback. For your set up, are you transcoding DSD->PCM with the HTPC (Foobar) and then sending Mch PCM over HDMI to an AVR, or do you have something different?
I think you mean that you can send DSD derived directly from SACD playback on a disc player, but not DSD from HTPC (foobar), over HDMI to your AVR. Based on my reading on forums, the reason you cannot play DSD over HDMI from HTPC is because of the lack of necessary DSD drivers for HDMI on PCs and 'computer hardware'.That's it. I was hoping that my AVR (Yamaha RX-A3050) would take DSD over HDMI but it won't. Takes it fine off the disc of course
I found out just tonight that Kodi 19.5 will play the DSFs. And transcode them to AC3 for SPDIF-ness in my other room, which is nice (but a bit pointless as I already have them in MCH FLAC, but hey).
