watchnerd
"If, as DIY audiophiles we want to break the rules and play with some 2nd harmonic, we want some cheap and practical way of doing it. The first option is to buy some Triodes (for example low voltage 6922's) and some other parts plus the equipment to build and calibrate a single-ended gain stage with just the right amount of 2nd harmonic. This is a very rewarding approach whose only drawback is the time and money.
Alternatively, the musical instrument company Korg, working with Noritake, has developed a Nutube, which is a tiny dual Triode about the size of a computer chip that runs on a tiny amount of power and delivers 2nd harmonic on demand. An excellent solution, it was the subject of my 2017 talk at Burning Amp Festival, and my write-up of that can be found in the Articles section at www.FirstWatt.com
But here we are going to explore this effect with a common inexpensive Jfet on a little circuit board powered by a small wall-wart. I don't think it can get any simpler or cheaper."
https://positive-feedback.com/audio-discourse/the-pass-h2-harmonic-generator/
