Optical cables?
abdo123
Brussels, Belgium
I was wondering if anyone sells short USB optical cables (or extenders) specifically to break ground loops and not bring noise from the host device.
It should be 1000 times more useful than your run of the mill snake oil cables.
Any suggestions or experiences?
Wes
you'd need a transmitter & receiver (both doing conversions) too
there are better ways to deal with a real gnd loop if you have one
while the noise issue does not appear hearable, I can give you the name of a guy who knows this stuff in & out
A
abdo123
Brussels, Belgium
There are options online, but they are incredibly expensive, long and meant for very high data rate.
Definitely too much for Hi-Fi use.
I’m kind of curious to see if it will bring the noise floor of a mediocre device I’m using. It will be an interesting experiment and might induce a paradigm shift in this forum :p
SIY
Alfred, NY
Why USB instead of a standard spdif optical? Power?
ReaderZ
I know nothing about price of these, but I highly highly doubt they even come close to price of some hi-fi cables out there...
A
abdo123
Brussels, Belgium
Because my SPDIF inputs are already occupied.
What i’m looking for is a cable that turns USB electric signals to optical signals and then back to electrical at the end device.
I would like to see whether this would improve the performance of devices with little noise filtering.
ZolaIII
Meh... Try to find a USB cable with split charge and data lines (or data only if you don't need power) with plug tipes you need and use cleaner power source (battery [power bank] , good phone charger).
Illustration is for addition of power (dato + power cable and added power) you want them separated.
Example:
https://www.amazon.co.uk/Delock-Y-Cable-USB-2-0-0-3m/dp/B009EAF0RU
Best regards.
A
abdo123
Brussels, Belgium
Example:
Best regards.
Wouldn’t the data lines create a ground loop themselves?
ZolaIII
@abdo123 nope, problem is in dirty power source (like lo quality switching AC/DC power unit in PC).
Me by if its horrible cable. I use Sony USB cables when ever I can (along with DAC with separate power input).
restorer-john
A wall wart such as you have described is usually a class 2 device with no earth/ground. The 0v may be floating at anything up to 80V+ with respect to actual USB Gnd. The neutral usally has a capacitor to 0v inside the wall wart.
ZolaIII
Illustration whose only for demonstration purpose. Usually they (with normal one's) use resistor on output end.
