oivavoi
How did it go with the omnis you ordered?
Quite recently, I set up some CBTs in a quite narrow space. The reflections from the nearest side walls were clearly best to absorb. But on the opposite side walls, where the reflections arrived at about 7 ms after the direct sound, I felt it became too dull with absorption. Despite that it was broadband. In this listening space I didn't have any arriving reflections arriving from the rear, since they went into another room. I think that might have been the cause of this. So I experimented with diffusion and also hybrid diffusion/absorption on the opposite side walls. This worked much better than absorption and especially diffusion with RPG Diffractal was awesome with the result of a very spacious and enveloping sound and without the detrimental effect of the specular energy with bare reflective walls (something that creating listening fatigue to me).
Regarding “how did it go with the omnis you ordered?”—that’s pretty well detailed in my prior posts since joining in on the thread—not sure what else you are asking about?
You did bring up a good point about room acoustics/treatment, something I only touched on in the thread dialogue. My living room is pretty good acoustically, with a lot of irregular surfaces; a slight sloping ceiling (2 by 6 redwood on edge, so groove every 1.5”) with and no highly reflective drywall walls (the walls are redwood paneling), almost all glass on the left side but with 2” wood blinds, a large limestone fireplace on the right side, etc.. When I ran Audessy on my prior Denon AVR, the room correction EQ was very minimal, not noticing much difference with EQ settings engaged or bypassed. I didn’t even do anything more than set channel levels and speaker distance when switching to the current flagship TOTL Yamaha AVR (had to replace the Denon when I went to 11.1 ATMOS) I could add some room photos if helpful.
I moved the smaller Duevels, the Planets, to the kitchen, and frankly, they don’t sound all that great, but nothing will in that room, very long and narrow, with almost all reflective surfaces. I am planning to do some room measurement and EQ at some point in the kitchen.
Your comment about listening fatigue, made me think of another observation: While shuttling several speakers back and forth in the main living room 2 channel system, i found that the Enterprise could be listened to for 12 hours straight with no fatigue, something I can’t say for the other conventional forward firing speakers in the rotation. I did not play the Omnis for a couple days, and when inserting them back in, I have played for 12 hours a day for probably the last week. “Listener fatigue” may be a vague subjective observation, but the Duevels only made me want to turn it up a little louder, something the wife noted after a bit. I now have an 11PM curfew in place……. Yesterday she said “you do know you have been playing that for 12 straight hours?”
