Sounds completely "solved" to me, good choices!I think my front end is “solved”. Benchmark DAC3 direct USB connect to Roon core, Benchmark AHB2 amp
Welcome! It’s a great forum to learn a lot about sound reproduction.
That is typical ‘distributor disinformation’ and further time reading on ASR will help flesh out how and why.
It would be interesting to know more about your original amp, to help understand whether your observation above was entirely placebo effect, or related to true differences in the sound waves.
Further time reading on ASR will also help flesh out how and why “checking out the reviews floating around” is abysmal advice, if one wants to avoid being misled in relation to hifi gear. It’s one of the main reasons ASR was created.
As you persist with omni speakers, the phenomenon of personal adaptation will take hold, and you will care less and less about their shortcomings. But they are, indeed, a lower-tier solution for sound reproduction generally, while still capable of being very satisfying. The “omnidirectional loudspeakers = best design available” thread starts with a post full of classic omni fan misconceptions and misdirections. Over hundreds of posts and much disputation, a more balanced view emerges of their real place in the audio pantheon.
cheers
Lets just make a quick clarificationI am decidedly NOT an amps sound different guy, and was shocked how much better the sound was with the Benchmark, but now that you called me on it, I may have egg on my face.
Even a omni that is completely linear in a 360 pattern, the reflecting surfaces are going to reflect in a completely non-linear fashion.
I don't believe anyone here claims "all amps sound the same".
Just the opposite, many amps sound distinctively different, and there are easily measurable and explainable reasons for this. Mainly in how they react to the impedance's of both the source and the load can be cause for big non-linear reactions. Or some are purposefully voiced to sound in a particular way, more.
When folks try to discredit the objective approach, they use stupid extremist statements like that which are miles away from the reality.
Amp listening tests have to be blind (of course!) and level matched (by voltage on a test tone, usually 1kHz, at the speaker terminals), if you want to be sure that you're not fooling yourself.I’m usually pretty careful on tests, even if subjective ones, when doing A/B comparisons. I’ll be even more careful here..,
@jim1274 now that you have had a taste of omnis, it's time for you to start saving for a pair of MBL's or hope that a pair appears second-hand at an affordable priceYou should do your best to go listen to them, they are truly remarkable speakers.
Come to think of it, I do have omni speakers at home ... only that most people here wouldn't think of them when they think of omnis. Ultimate Ears Boom bluetooth speakers ... maybe I should get another speaker and listen to them in stereo.
soundmatters.com
Nice example of the influence of what we see on what we (think we) hear:
www.audiosciencereview.com
Yes, input volume has to be adjusted seperately for each amp.
It's a pain, which is why hardly anyone bothers to do it.
But having participated in several such tests (long ago, when my hearing was much better), I personally don't believe anybody's claim of "amp A sounded better than amp B" if they didn't do it.
YMMV.
What to do about the ABX test?
Seems increased commentary in recent weeks about ABX tests. Much of it stemming from people who come to ASR to set us straight about trusting our ears. I do agree with some who have said that calls for ABX or it didn’t happen have become almost like a club to beat people over the head with, and...www.audiosciencereview.com
For example. If you were to play a white noise tone out of a hypothetical omni speaker that was dead flat in 360 under anechoic conditions, put it in your room and measured the response at the MLP, what do you believe that resulting measured response would be?I still don't understand why you are using the term "completely non-linear" to describe reflections that would have virtually the same spectral balance as the direct sound. What would be "completely non-linear" about them?
Isn't that also an argument against any speaker with wide, even dispersion (you know, the ones that we all celebrate on ASR)?For example. If you were to play a white noise tone out of a hypothetical omni speaker that was dead flat in 360 under anechoic conditions, put it in your room and measured the response at the MLP, what do you believe that resulting measured response would be?
Imo these same attributes are desirable in the listening room, even if they are harder to achieve. I'm not saying omnidirectional speakers are the only, or necessarily even the best, way to get there. But when done right, omnis at least get the reflection field spectrally correct, which correlates with natural-sounding timbre at home as in the recital hall.
In your example, the ungated in-room measurement will look like hash because the reflections will be arriving from many different directions, with many many different path lengths, and therefore with many many many different phase relationships at all the different wavelengths, as they combine at the microphone in-phase and out-of-phase and in semi-random phase.
Leaving all that aside and going back to your question on non-linear reflection lets just take a simple case.I still don't understand why you are using the term "completely non-linear" to describe reflections that would have virtually the same spectral balance as the direct sound. What would be "completely non-linear" about them?
Yes, sort of, but there are extremes and moderation in all things.Isn't that also an argument against any speaker with wide, even dispersion (you know, the ones that we all celebrate on ASR)?
Anecdotally I agree with you about head in a vice imaging (I own Sanders Electrostats). But I disagree that omnis are an extreme too far - one of the best systems I’ve ever heard is an MBL system.Yes, sort of, but there are extremes and moderation in all things.
I've always found omnidirectional speakers to be an extreme too far.
The tightest most focused images I've ever experienced came from horns that beam like a laser.
Yes the best imaging result is head in a vise like at the MLP, but inside that vise, the focus was incredible.
Try listening to some Q sound processed CD's like Stings - Soul Cages or Roger Waters - Amused To Death.
The immersive qualities for a 2ch recording can be startling if the system focus well.
One sound leaves the speaker and reflects off a hard window surface on the left side and then reaches your ear.
That same sound leaves the speaker and reflects off the soft surface of the couch under that window, then reaching your ear.
Will the two have the same spectral balance or be non-linear both to each other and to the source?
There is also the fact that I don't listen to classical music and have no interest into turning my listening room into an approximation of my favorite hall.
My music, except for the few live recordings, are created in the studio and if I wanted to recreate anything it would be an approximation of the recording studio where the engineers sat while mixing.
My music, except for the few live recordings, are created in the studio and if I wanted to recreate anything it would be an approximation of the recording studio where the engineers sat while mixing. For many years my main listening interests have
involved Quad, 5.1, and now Atmos and the other immersive technology. We live in totally different worlds with different goals.
