420 without subwoofer, which is better, KH 150+kh7502.2 or Neumann KH420?Even the KH420’s won’t be positioned optimally to fight room modes. Only multiple subs can help to even out the low frequency peaks and nulls.
In other words, KH420’s with dual subs is optimal.
你在考虑KH
Yes, we don't have that much equipment here. I'll defer to your experience and advice.These kind of questions baffle me.
While i don't know where are you from, if you are willing to throw that amount of money on speakers, shouldn't it be worth it to go to the dealership and listen for yourself ?
If we put presumptions and guesstimate responses from people who never listened it and compared it aside, if you're very lucky you may find 2 or 3 guys who have had the opportunity to make side by side comparison (anything less is worthless because different rooms will sound different).
What will you do if two of them say A is better than B (or vice versa) or if all three say B is better than A ? You'll take their word for it and go buy it online ?
JBL M2s don't like them, I wouldn't pick them upNot related to your question, but those little kh150s on those massive stands in the middle of the room, makes me realise why so many are not into hi-fi.
BTW if you are considering KH420, why not stretch to JBL M2s?
+1"not considering price" then sweetchaos has the correct answer.
Can't a 150+750x2 reach the sound pressure of a 420?A lot depends on the room you're in. The KH150 are very good for close listening, where the KH420 are better from a distance. Both can use help from sub if you want it loud, but the KH420 goes louder than the KH150 and lower, but in a big room, and to fight room modes you better have subs with it anyway.
I think the main consideration needs to be how far are you from your speakers. If it's more than 2m take the KH420, if it's closer take the KH150. And add subs, even if it's only later on when you get the KH420.
Without subs vs. two way with?I would always tend towards a 3-way
With or without subWithout subs vs. two way with?
maybe it does, but not as clean and controlled in dispertion, what matters if you sit a bit further from the speaker.Can't a 150+750x2 reach the sound pressure of a 420?
So nice that it makes you prefer it regardless of the multisub and DSP advantage of the on topic alternative?With or without sub
A dedicated mid dome driver is nice to have
You can always add subs in the futureSo nice that it makes you prefer it regardless of the multisub and DSP advantage of the on topic alternative?
But the question is what sounds better, not what has the most upgrading potential.You can always add subs in the future
And also the DSP
But you can't add that driver later.
