Bear123
- Joined
- Nov 27, 2019
- Messages
- 796
- Likes
- 1,370
There seem to be two types of reactions to speakers/items that have a strong following and measure/perform poorly:Thank you for another interesting review @amirm . I don’t understand all of the angst regarding this speaker.
-It is a current offering from the manufacturer, so it should be judged against what we now know about speakers and against current offerings.
-On axis isn’t flat or even
-Directivity is poor
-Other speakers in the price category have measured and sounded better (Some even active)
-Bass is poor
Measurements showed overall poor performance. Subjective Listening tests too showed it didn’t sound good.
Over the years this has seems to be an often suggested model at places such as AVSForum. It was a very good choice to review... now we know. Thanks for purchasing, testing, reviewing, listening to it, and writing up the review.
1) Gratitude for shedding light on the poor performance, in order to dispel the subjective myths about a product and get if off of the "often recommended list"
2) Anger that a product believed to be good tested poorly, so attacking the messenger delivering the message of poor performance. I've seen this happen with other products that have a strong fan base.
I do think the sub par bass extension makes these a poor choice(along with the other issues) unless diminutive size is *extremely* important. Crossing to a sub at 150 Hz is going to be an issue. For example, the Infinity R152 would be an infinitely better choice at $129/pair. Pun intended
Edit: part of what makes crossing to 120 or 150 an issue is that a huge percentage of subs do not perform well to a high enough frequency to cross to this speaker. And that frequency is not 150 but probably more like 200-250 Hz in order to effectively crossover. Not many subs have that capability, and even if they do, localization would likely be an issue.
