New SMSL D10 dongle.
Joffy1780
No battery and no DSP, there are already a few of them, including with windows.
probbably not $69 either
but it is a dual dac design so bom cost is up there and of course, the Topping name is the gold standard for build quality, post sales service and device longevity
everyone knows that
everyone knows that
Sure :facepalm:
So you mean that Topping makes it for SMSL? ;)
everyone knows that
The cost pressure from the Dual CS43131 does not seem to be that high.
Blon V1 Pre-Order with DUAL CS43131 DAC CHIPS € 37.77
i got the d10 and would suggest to get the slightly larger shanling up4 2022 for the same price instead. the shanling sounds warm, while the d10 sounds piercing in the treble. overall the shanling is much more refind sounding with much better soundstage (specially layering) and you also get the whole bt functionality on top. ok, you dont get 500mw @32ohm but i still drive my hard to drive full size planars with it without a problem. finally the d10 isnt bad for the price, but it isnt special by any means.
I ordered one on impulse.
After 15 minutes, I repackaged it to send it back.
Probably it was defective.
Sounded bright and harsh. Would clip and compress if pushed.
100% it does not produce 500mW per channel, though I did not measure it.
I wanted to do a full test, but wasn't worth my time.
I am surprised by the negative experiences. Up until now, SMSL has shone with clean devices. I'm also surprised by the output power specs.
You are surely joking.
Not to mention this (the same issue was with the SU-9):
You dig up ancient reviews, and ask me if I'm joking?!
My D10 has arrived.
While I was unable to achieve the desired volume with the Space on the Sundara (+EQ), this is no longer a problem with the D10.
The D10 therefore can deliver much more power. In addition, with the SMSL, in 4G, Idon't have any noises, like I had with the Space.
The sound is very dynamic and clean.
I'm very satisfied.
This kinda surprise me since SMSL doesn't specify any additional opamp used in the amp section and relying only on the integrated hp amp of the CS43131 the output power should be on par with what you get from Space, Sonata BHD Pro or Fosi DS2. At the same time SMSL doesn't clearly specify 500 mW PER CHANNEL so i was almost sure they were "cheating" referring to combined power (2x250 mW).
If you notice a tangible difference with Space then there should be some undisclosed additional opamp in the D10 (maybe you can try to check the board through the big window), unless you were using the Space in low gain without noticing it.
Thanks for the tip. I actually had the Space set to low gain. But even if I set it to high, the D10 is louder. But it certainly won't be 500mW per channel.
SMSL D10
DAC Chip: Dual CS43131
Op-amp: Dual SGM8262-2
Code:
      ========================== Summary =========================
Vendor ID                : 0x152A (Thesycon Systemsoftware & Consulting GmbH)
Product ID               : 0x85DD
Manufacturer String      : "Speed Dragon"
Product String           : "SMSL D10"
Serial                   : "5000000001"
USB Version              : 2.0 (480 Mbit/s)
Port maximum Speed       : High-Speed
Device maximum Speed     : High-Speed
Device Connection Speed  : High-Speed
Self powered             : no
Demanded Current         : 100 mA
Used Endpoints           : 4
C Major test
- Set Foobar2000 volume to around -17 to -16 dB.
- Set Foobar2000 output = Default : "DAC" [exclusive].
- Set Win10 volume to max.
- Set DAC's hardware volume to ~max.
- Use Superlux HD572A (24Ω 102dB/mW => 118.2dB/Vrms) most sensitive Headphone that I have.
SMSL D10 = NO clicking noise
SMSL D10
Code:
Product ID               : 0x85DD
Self powered             : no
Used Endpoints           : 4
C Major test
So it implements sgm8262-2 opamps, this kinda explains the volume achievemnts disclosed in previous posts, nice!
A bit surprising it doesn't show DRE artifacts, would be nice to se it measured.
