Thanks. Form factor and construction on these ticks all the boxes for me.No shouty mids with producer pads.
Different kind of 'forward' sound than HD600.
HD490PRO has more comfort, better bass extension. Is more dynamic (mixer) and warmer (a bit bloaty) with producer pads.
Whether or not one finds it an upgrade or too expensive compared to any other headphone is mostly a matter of personal taste.
I suspect that with EQ to the same target they will be difficult to tell apart, aside from comfort and fit.
490 vs your modified 58X? Thank youThey have the same driver but, yet again, different front and back damping, different enclosure, different pads.
The drivers are tighter in tolerance (probably pre-selected) so there will be differences between NDH30 and HD490PRO. I suspect that with EQ to the same target they will be difficult to tell apart, aside from comfort and fit.
NDH30 is too expensive for me to buy/try.
Returned the HD490PRO so cannot compare directly anymore anyway.
maybe to add to your question, I was curious, is the driver on HD58X related to the ones used on HD560S and HD490 PRO? the impedance is different so it's safe to say it's not exactly the same, but how similar/different are they?
This is an interesting review. Mostly subjective, but the author is clear about it, and he also outlines how small are the differences between these headphones in the end (no bad choice).
I don't know, but I wonder if it coincides with what makes a headphone good for gaming. This reviewer is apparently well known at trying to decide on a best:This is an interesting review. Mostly subjective, but the author is clear about it, and he also outlines how small are the differences between these headphones in the end (no bad choice).
What would make a HP “better” for binaural? Is it FR-related only? Low distortions? Something about phase or group delay? Some other characteristic not often measured?
Or, is the HD490 just happens to “enable” the best HRTF for the author, and therefore the best binaural experience?
Headphones cannot by themselves turn stereo into surround.I don't know, but I wonder if it coincides with what makes a headphone good for gaming. This reviewer is apparently well known at trying to decide on a best:
i figure since this headphone (and a few others recently, like Sony MDR-MV1) are meant for "3D sound" (Atmos?) that they should be judged accordingly. Though I don't know how a headphone can accentuate 3D sound qualities without DSP. It is always (or usually, with full size headphones) just two speakers, so I would think you are always really hearing stereo.
All beyond meHeadphones cannot by themselves turn stereo into surround.
However, many video games nowadays use HRTF processing to bake binaural surround sound into their stereo output.
The result can be very effective (e.g. Hunt: Showdown), however, it depends on both the quality of the HRTF processing and on certain aspects of the headphone or IEM.
The review site rtings.com tries to quantify these aspects with their imaging and passive soundstage tests:
Our PRTF Scores And Tests: Headphones
Our pinna-related transfer function (PRTF) test measures the amount of interaction between the pinna and headphones.www.rtings.com
Our Stereo Mismatch Scores and Tests: Headphones
Stereo mismatch is a crucial component of the headphones-listening experience that helps us assess the performance of drivers in relation to each other.www.rtings.com
Apple for example, uses their vertical integration to achieve remarkable binaural surround sound.
The same Face ID sensors that unlock your iPhone are used to 3D-scan your head and ears, based on which they modify the HRTF processing.
But if it needs software to sound more 3D then it suggests the software is doing much of the work, not the headphones (which use the same driver as the HD 560 and HD 400 Pro). And the same software could be used to make other headphones have similar effects, though perhaps not as well.
I like the HD560S very much (still playing with EQ to fine tune it). I also have the HD650 (great “as-is”), 600, and 800S.Yep.
I agree with other things the guy in the video says (rankings and reasons).
Unfortunately, about the DT1990, his ranking could become different when he would have used EQ or a filter to remove the treble peak.
The comfort for S5X can be improved upon by bending the metal headband strategically to fit your head. While that works and makes it comfortable it may then not be for other heads. When only used for 1 person and bent for one's head the ranking becomes different. Of course this is a design thing. Another annoying thing is you can rotate the cups endlessly eventually you either have to remove the connectors, unwind the cable and plug it back in or rotate the cups back.
OLLO has steps to make in this department and create a better headband and lower cable microphony.
I ended up keeping the S5X (but modified one to change the properties the guy complained about) over the HD490PRO despite the excellent and better comfort of it.
That last bit is an important factor for some (me in any case).
The producer pads were just a bit too warm and fuzzy in the bass. The mixer pads had great bass but too forward/bright. The HD560S(400Pro) is right in the middle which is 'better' for enjoying music in a 'natural' tonality. This is not the design goal / purpose of the HD490PRO. It is a tool that can be used in 2 different production stages.
Still curious about NDH30, which also uses the same driver but selected on very tight tolerances and has different damping scheme. The HD490PRO also has a different damping scheme, positioning, pads, driver-ear distance and angle and this all differs from NDH30 as well.
Horses for coarses.
) to better understand what it is about having a great mixing headphones or, as in the above review, a great binaural tool.
