There are many devices (not just audio) that can be damaged by a failed firmware update.I performed this update with the HDMI plugged in and lost CEC functionality! A subsequent update to try and fix this bricked the device and I had to go through a lengthy returns procedure.
You shouldn't be messing around with the reverse main power button, especially during an update. I haven't tried to update my replacement as I'm afraid of bricking it again.
Topping E30 has XMOS XU208 USB chip. The amplifier from the topic has the latest XU316 chip. And it has a different product ID that may not be recognized by your tablet. But I could be wrong.Yes I tried with topping E30 II and It works.
After 10 and more tries I found an otg adaptor that works this morning.Topping E30 has XMOS XU208 USB chip. The amplifier from the topic has the latest XU316 chip. And it has a different product ID that may not be recognized by your tablet. But I could be wrong.
Wow! Congratulations! You have succeeded. Can you please share a photo and name of the adapter here for others?After 10 and more tries I found an otg adaptor that works this morning.
On my TV (Toshiba 50C350KE with Vidaa OS, with HDMI connection), when I adjust the volume on the TV remote, it changes. But within the limits set on the amplifier. So I'm not sure that the volume changes on the amplifier, it's more like it changes on the TV. Also, when the amplifier connected via optical S/PDIF, the volume is not adjusted at all from TV remote control.meaning turning on volume on TV should turn volume on amp, right?
All 3 points shouldn't be the case with this amplifier.I like the A0300 very much, but with my speakers there is an absolute loss of treble. Given that I only purchased this for playing music that I drum with the quality drop isn't that concerning.
I had been using an older entry level Denon integrated amplifier for the task previously and without a doubt it sounds better than the A0300 and probably has more power which is surprising. I doubt that it actually has more power, but as a class A/B amp it probably is able to sustain the power level.
I find the A0300 starts to sound flat and somewhat compressed after a few songs at higher levels. The speakers are some basic, but effective Celestion DL-8 Series Two. Anyway, for the price, and as an all in one solution for my use the A0300 is solid. I have no regrets at this point.
Sure, I use Bluetooth, LDAC, mostly streaming local files that I ripped from my CDs to Flac (using my old LG G8x as a dedicated streaming device now). Sometimes it is from Tidal. My understanding is that with class D amplifiers they are prone to interaction effects with the speaker, and depending on the speaker's response characteristics, you may or may not have an audible change. I am no expert so perhaps I have misunderstood.All 3 points shouldn't be the case with this amplifier.
May I ask which input and source you are using?
You should test with a reliable and directly connected source and compare with your Denon.Sure, I use Bluetooth, LDAC, mostly streaming local files that I ripped from my CDs to Flac (using my old LG G8x as a dedicated streaming device now). Sometimes it is from Tidal. My understanding is that with class D amplifiers they are prone to interaction effects with the speaker, and depending on the speaker's response characteristics, you may or may not have an audible change. I am no expert so perhaps I have misunderstood.
If you have determined that USB sounds better than LDAC, and you have done so by sighted listening, that is just not proof at all. If you are able to tell LDAC from USB, 9 times out of 10 in a level matched, blind listening test, that is evidence.I still didn't updated, but I have no more pops in usb only with bluetooth. As to respond to some posts before, Ldac is good but USB is better. I have Polk Xt20 and just put +1 in treble, direct and I really like this amp more everyday, especially with blues and R&B. I will try update tomorrow, I still want to figure out different filters.
As out of topic, which is an amp not class d in this similar price range, with similar performance? Just curious
How do you envision this being done with this device?quick question i know this has sub out but has anyone been able to do a simple hometheater setup right left channel AND a center channel with a sub??
