Neutral, low-budget closed-back headphones?
Veri
Too bad they've been discontinued. They look pretty cool. I see a used pair for $150 on US Audio Mart.
Stock without earpad mod, they are a tight on-ear fit, though. With larger ears this might be unbearable but for me personally it's passable. Just not "comfortable". Hence the looking at new earpads :)
bobbooo
My work is high concentration so I normally don't mess with my phone unless I'm taking a break, when I usually leave my desk.
I'm holding out for a new job and a companion Atom DAC:p
You could just use an old phone, or an Android DAP. The brilliant Neutron Player app has a max 30-band parametric equalizer built-in, so you can apply Oratory1990's excellent EQ profiles. Here's a full-featured trial.
Or you could wait for the Qudelix 5K to come out next month, which has a 20-band hardware PEQ for system-wide EQing of any source, the choice of USB or Bluetooth (including LDAC) connection, and dual ES9218P Sabre DACs (the same as in the lauded LG phones like the G7) with a max 4V max output (balanced, 2V unbalanced connection available), so should power pretty much any headphones. It's made by the same developer as the ES100 so I have high hopes.
617
Somerville, MA
I find the Sennheiser HD380 to be very neutral and comfortable. I listen to them all the time.
pozz
pozz
Слава Україні
Editor
I've known of Neutron for while though I've never tried it. I'm not into portable setups to be honest. I mostly use my phone to read and check email.
pozz
pozz
Слава Україні
Editor
LightninBoy
St. Paul, MN
The K371's are not exactly neutral as they follow the Harmon target. The neutral monitoring version is supposed to be the K361, which I have not tried. Guitar Center and Sweetwater have some offers for them I think as they BT version is on its way.
When someone says "neutral headphones" I assume they mean the Harman curve, becasue if they mean "flat" from 20-20K then that would be like ice picks in the ear. Is there a different "neutral" curve and if so where can I go to read about it and the supporting research?
pozz
pozz
Слава Україні
Editor
Reactions: SMc
pozz
pozz
Слава Україні
Editor
Real gems in this thread.
SMc
Creative Aurvana Live (first gen) if you don't need much sound isolation for 55$ I think nothing comes close. The driver's are from Foster the 40 mm RP paper cone ones (my biggest regret is that Creative never made any with 50 mm one's).
Mesurements:
https://www.innerfidelity.com/images/CreativeAurvana.pdf
You can find review and disassembly there if interested.
I have these and use them daily! Great value. I got them to retrain my ears after years of Grados.
solderdude
The Neitherlands
I did measure the 780 ;)
pozz
pozz
Слава Україні
Editor
ZolaIII
The way they look reminds me of some DJ headphones, like the ones Pioneer made, from 10-15 years back.
Only great one's Pioneer ever made ware Monitor 10 II & that whose in mid 70's.
pozz
pozz
Слава Україні
Editor
Inner Fidelity
Pretty damn impressive.
Trawling through all these headphones measurements in so many sources really shows how much a standard, public database is needed.
pozz
pozz
Слава Україні
Editor
