Need some advice on DIY bass traps and their placement
Koeitje
So I got big nulls in my room at 40hz and at about 80hz (mainly want to fix the 80hz). The image below is my listening room. Things to note is that at the far end of the room I cannot really place anything and the front wall is sloped (the green line indicates where the slope is) with a radiator on the right where I can't really put anything. Since I don't want my room to look like a studio I want to put bass traps in Ikea bookshelves etc. I also have no way to fix ceiling reflections.
In purple I've indicated possible places I can put stuff.
  • On the bottom you see a bookcase I can put trapping material in (its about 30cm deep). I can also stick something to the side, because that's nicely out of sight.
  • I can put a room divider such as Ikea Kallax behind my couch and fill it with material. This would be about 1.5m in height and can be about 30-40cm in depth.
  • I can also put a bookcase next to the couch and fill that.
I plan to use cotton based insulation material. I can choose between 45kg/m3 and 25kg/m3 material. Thickness for the heavier type is up to 45mm and for the lighter material up to 200mm. But will all of this have any effect at all, because I cannot really put them in the actual corners...
Inner Space
If you mean nulls, rather than peaks, then traps and absorption won't really help. You could try moving the sub, perhaps along with rotating the speakers and sofa through 45 degrees clockwise, so that the main axis becomes diagonal. If none of that helps, then you could try EQ.
K
Koeitje
I guess I need absorption behind the source to stop the reflections from causing the nulls?
Vini darko
Dorset England
You could try reducing the distance between the speakers and listening position. Pull the speakers out a touch and move the couch forwards a touch. Getting further into near field will negate the room to some degree. Bass traps do thier best work at right angled spots in the room. Putting them on flat surfaces is likely to affect the mids and treble more than bass. That's my layman's understanding anyway.
K
Koeitje
Moving the couch forward does help a bit, at least I think...because I also did a measurement with the mic on the table in front of my couch and that was slightly better. But there isn't much room and I can't get to the optimal position there, so I prefer to solve it a different way..
patate91
Corner bass trap.
I put unpacked mineral wool in the corners behind speakers and the corner near my listening spot. I got improvement with bass dips.
Unpacked mineral wools are great to experiment. Alter you can do something that looks better.
patate91
Your room looks like mine
K
Koeitje
Corner bass trap.
There is no space except for the corner behind the left speaker, but even there its limited due to the slanted ceiling (starts from the floor).
Vini darko
Dorset England
Sorry I don't have any better suggestions. Hopefully one of the experts here can help with some maths based solutions.
K
Koeitje
Maybe a second sub will fix it, then I can put one behind the left speaker and one on the right of the couch.
Dj7675
Not sure what your electronics are or if it include room correction or not, but to have the greatest affect on room modes:
1-Go with 2 subs, maybe put one behind the left M106 Possibly? Even if you have to do 2 smaller ones
2-Use eq below 3-500hz
Also with the M106 do you need to absorb the first reflections at all? Their reflected sound and direct sound will be very similar which should just get it a nice sounding wide image. Just a thought.
tuga
Oxford, England
You could try hanging a very heavy curtain behind the listening spot / sofa (partitioning the listening room from the office) from a rail that you can slide to the short wall next to the door when not in use. Unless of course you enjoy the effect of the low end bouncing back from the back wall and arriving at a later date... Or maybe add absorption to the back wall? 11 metres is a long distance.
K
Koeitje
Yes, a second sub behind the left speaker is still part of the plan. I already have one SB2000, will be on the look-out for a second one. I'm trying to deal with <500hz, above that its fine. I would maybe want it to roll off a tiny bit more, but maybe that changes when I fix the issues below 500hz.
I'm not sure what impact the length of the room, but a curtain wont stop <500hz that's why I was thinking about a room divider stuffed with something that absorb lower frequencies. I can stuff about 1m3 worth of material in one of the top corners at the end of the room, but that's about it.
pozz
Слава Україні
Editor
To clarify vocabulary.
  • "Bass traps" should be reserved for pressure-based designs like membrane or Helmholtz type.
  • "Broadband traps" refer to velocity-based traps using insulation materials and so on which have no effectiveness <100Hz.
Pressure is greatest in rooms at walls, so a common bass trap mount is directly on the wall. In corners you have even greater pressure given that's multiple walls meet, which is why those traps are set there as well.
At bass frequencies you cannot negate the room in the sense you mean. Bass frequencies are modal in small rooms, which means they will cause different areas to be differently loud and soft. Speaker and listening position placement will help find the most even area.
When you move closer to the speakers you are increasing the direct sound vs. reverberant sound. This is most effective for frequencies above the transition region.
Room treatment can help with nulls as well as dips. Standing waves are most affected, while room modes will show only slight improvements (room modes are peaks/nulls based on physical room dimensions... they are room resonant points; standing waves are peaks/nulls due to phase cancellations/additions from the speaker/room interaction).
@Koeitje in a large space like yours a few isolated traps won't do very much. You will need an incredible amount of treatment to stop SBIR effects.
Just from rough simulation, using 11m length and 3.6m width, your 40Hz/80Hz issue is modal in nature. You can't really get around it unless you reposition where you sit, and it seems like you are very constrained seeing where the doors are.
A second sub and EQ to pull down peaks after measuring using MMM will help, but no amount of added bass or EQ boost will make those modes disappear.
dasdoing
Salvador-Bahia-Brasil
the nulls are probably caused by http://arqen.com/acoustics-101/speaker-placement-boundary-interference/
the biggest mode is produced between front and backwall, so and absorbent room divider behind the couch could(!) have some effect.
placing material directly on the wall wont do much.
I never heard or meassured sound in a sloped ceiling room but I imagine there will build up lots of energy on the bottom "corner" where ceiling and floor are close. putting material there would be effective
pozz
Слава Україні
Editor
About these I have no strong opinions other than the second, which should be avoided since having absorption immediately behind your head will ruin the sense of spaciousness.
The other thing to consider is the effect of late reflections from the far back wall. Perceptually these will be more bothersome than the early reflections from your living room/TV room area. Maybe a heavy curtain in front or behind the bunch of stuff might help, depending if the stuff is solidly stacked or loosely arranged. Or maybe a broadband hanging baffle. An ETC in REW will help gauge how strong those late reflections are and if you need to treat them.
Dj7675
A well designed speaker doesn’t need side wall reflections absorbed. Side wall reflections from a well designed speaker with wide even dispersion will actually enhance the soundstage. From the many reviews of speakers it does seem that absorbing ceiling reflections does help many speakers. I would think speakers where direct sound does not match reflected sound would benefit from absorbing side reflections. The need to absorb side wall reflections seems to be speaker dependent.
patate91
Wider sounstage it's just one part of music experience. In my listening room the soundstage is limited to room boundaries anyway.
patate91
I re-read your post and I'm not sur I follow you.
Once soundwaves are in the roo
What kind of speakers eliminate SBIR effect?
