Need some advice on buying headphones!
GabrieI
I'm looking for wired on-ear headphones. Would the Klipsch Reference On-Ear II be a good choice? It meets all of my criteria.
On the other hand, I've never tried over ear headphones, and I've been told Sennheisers are great.
Should I get the Klipsch headphones, or something else?
Thanks for your help!
staticV3
It sounds like you're still on the fence regarding on- vs over-ear.
Is there a reason why you're specifically searching for on-ear headphones?
Jimbob54
Could you tell us what your criteria are please. Will help with responses.
Also, have you had the klipsch on your head and listened or has this been a desktop search so far?
Joe Smith
My personal cheap favorite is the AKG K361, over-ear, comfortable and decent room noise attenuation, Harman curve sound. Around $80. Some prefer the K371 for about $30 more.
