IAtaman
- Joined
- Mar 29, 2021
- Messages
- 2,515
- Likes
- 4,588
I bet it won't sound warm.I'm not sure. But now I'm curious how that would sound!
It might play chill music really well, though.I bet it won't sound warm.
The load was an actual loudspeaker, in this case, a sealed box 2-way minimonitor.1) Amp test on resistive load and (simulated?) speaker load.
2) Test of the hiss by placing the hear close to the speaker ( a decibel meter would enable quantifying the result).
Only think that is missing is a thermal measurement with the amp at full load.
I tend to believe you. Still, it's an interesting topic that perhaps deserves some attention, since our job here is to obsess over measurements![]()
As you know, it is an Oxymoron. Everyone (almost) tests with resistors only and when listening, no speaker is a resistor only.
Beating-the-dead-horse-dept:And no one listens to continues sine waves which you used in your testing. And the load you created doesn't match any real speaker whatsoever. You sure you want to keep going this argument?
Remember what I said at the outset. We do this test and then what? What reported audible problem are we catching with it?
I (re-)submit that the most complete way to test an amplifier is to include a rigorous load-pull, same as we do with RF amps. One doesn't need to re-run every parametric test,
You already see the problem with different resistive loads in the second graph. You don't need the simulated one to know the output impedance is too high. I run such a test on all class D amps and point out when there is an issue like that:whilst I don't agree with @pma pma test as implemented here, I would have thought the usefulness of testing with loads representative of real speakers would be obvious.
Two different amps. Black traces are the simulated speaker load. Rest are resistive loads.
A speaker simulator would show a wiggly response but the point is already made without it.
That's a huge jump to conclusion. We haven't seen a real complex load test. And even if one does it, does that bear precedence to all other amps?Well, the original premise was interesting in that the amplifier load was presented as a rare but potentially realistic case for a speaker. The more the topic was detailed the more apparent it became that this is not the case. In that regard, the measurements are not really more interesting than connecting your amp to the fridge to see what happens in my opinion.
I read this as a rephrasing of turning the blind eye to what potential could be more knowledge. -Which should be every ones priority. Science is also to break new grounds. Maybe it's succesful, maybe it's not. But it's saddening to not try.Indiscriminate skepticism is no more useful than blind faith.
I don't mean to sound harsh - it's just that without a heuristic approach, anything and everything can seem equally plausible and we can potentially ask endless questions without ever figuring out which questions are most important to ask given the limited time and resources we have, and the knowledge that's already been established.
I did links to this. -As a way of means to argue for a better load circuit and to question that of OP's. Not to defend OP's test circuit. Quite the contrary. I think that is obvious if one don't just skims the thread but reads the posts.For others who are citing equivalent circuit models with large capacitance in them (like whomever linked to this page) seems to fail to see that Rc (e.g. at least a few Ohms) and Lc are both in series with it, so that is not at all like what PMA is using as a load. The last plot at the bottom of the page shows that the impedance magnitude is increasing (inductive) at high frequencies, NOT capacitive.
Thanks Amir. I think this is the third or fourth different way you've tried to explain and show that this "simulated real complex speaker load" test does not reveal anything that your existing tests don't already reveal. ( don't know why so many folks here are unable or unwilling to grasp this basic information that you keep trying to provide.
audiosciencereview.com
You made my day. However I’ll bet someone will indeed say it’s surprisingly warm with an airy and tall soundstageI bet it won't sound warm.
Sorry Amir but your understanding is not correct and demonstrated by the plots I already posted.
This plot shows that the various resistive loads (coloured libes) present a relatively flat frequency response in band, yet the reactive load is all over the place.
This plot shows flat response on resistive and reactive loads.
You also have the secondary issue of reactive loads creating excessive heat dissipation in class AB amps or bus pumping in class d.
Yes, also Amirs example and data shows that particular amps response only significantly deviating out of band. In band it's reasonable, if not perfect. You could easily interpret this as being an issue of minor consequence.That "wiggly response" I think shows a lot more useful info than the flat line of the resistive tests. It reveals how and where the sound profile is affected.
Below is from a post from @damonhill (black trace is speaker load). (NO SOURCE @damonhill ??)
NC252MP (class D) vs. A250W4R (classAB) burst measurements into 4ohm//2.2uF load
I'm not sure. But now I'm curious how that would sound! I bet it won't sound warm.audiosciencereview.com
