There is no DPS neither on the amp nor Subwoofer.It depends on what you're using it for. If it's home theater most processors and receivers have dsp built in so not really needed. In a stereo set-up without built in dsp it would be a plus. I use 2 JL Audio Fathoms in my home theater and only use Audyssey.
In my room there is only three spots where it could go, so I hope one of them would be a good one. Do you think a smaller subwoofer, whether sealed or ported, would be easy to set up?No, sealed subs do not require DSP. If carefully designed and positioned, you can roughly match the room gain boost to the rolloff rate of a sealed sub, and get an in-room response with great bass extension. Sealed subs usually ship with DSP because most consumers don't know what room gain is, much less how to select a subwoofer to match it. It is always preferable to have customers think there is a bit too much bass extension, rather than too little.
The subwoofers I am doubting on don't have DSP nor Linkwitz (AFAIK). They are active, and can ensure they don't have DSP. If DSP is required for Linkwitz, they don't have it neither.You do need to EQ the bass region (room influence to it) more than anything else sub closed/ported or without it. Closed sub's will interact with room less than ported one's and arguably should have a better impulse response or time domain if you like, meaning less echo. On the other hand port will enable ported one's to go lower but on higher SPL levels you could hear the port, in order to extend it's lowest end and level it up closed sub's will incorporate Linkwitz transform function towards excursion rates of driver's used and amplifier power (done by manufacturer for active one's of course).
That is a 220dB scale...@alex-z a single simple PEQ (to shave sub) and only one sub no crossover or anything else:
With a bit of luck of course.
One with PEQ is blue line and more like 6~7 dB to 70 dB line, anyway not a problem to level up even more by simply lowering the sub volume a bit. It whose with SVS SB 1000 Pro (which does have DSP) and done on Flex but all of that is less important.That is a 220dB scale...
It quite clearly has 10-15dB of variation in the bass response.
A PEQ is not in my setup. I tried to find an option to implement something in that way but at the end I didn't happen. Would be a Loki MIni+ a PEQ? I guess you are talking about something that has a more subdivided frequency adjustment.@Zeppelin I mean range up to 500 Hz and with PEQ, not crossover parametric filters.
What is jour price range and what exactly do you want to accomplish?
It's usually relatively cheap (simple) circuit board embedded in sub enclosure along with amplifier. It can be done and with digital signal processor of course
In my "understanding" of the subwoofer positioning situation it seems to me the ported would be more dependent of corners, table/shelf on top, distance to the wall and may be some others variables. Am I wrong thinking the sealed would not have to struggle with those variables?Sealed or ported subs do not significantly vary in their difficulty of room integration. As a over-generalized rule, I would select sealed for small rooms simply because of the extra room gain that will be present, but there is no reason why a ported sub could not sound good.
As long as you don't block the port badly, you have about the same considerations as sealed.In my "understanding" of the subwoofer positioning situation it seems to me the ported would be more dependent of corners, table/shelf on top, distance to the wall and may be some others variables. Am I wrong thinking the sealed would not have to struggle with those variables?
Whose in generally up to 500 Hz on both speakers and sub's.A PEQ is not in my setup. I tried to find an option to implement something in that way but at the end I didn't happen. Would be a Loki MIni+ a PEQ? I guess you are talking about something that has the frequency more divided.
But what surprises me is you are talking about freq above 500hz, which is a matter of the speaker, not of subwoofer, and I don't understand why adjusting the low frequencies on speakers will benefit the subwoofer. Can you explain me that?
This graph helps to clarify.@alex-z a single simple PEQ (to shave sub) and only one sub no crossover or anything else:
