- Joined
- Aug 14, 2018
- Messages
- 2,776
- Likes
- 8,162
I recently got a MiniDSP SHD, and I had the common problem where it makes a hiss/noise when in standby - silent when on and operating, and of course silent when fully switched off. The hiss and noise happen only when the rear power switch is On, but the unit is turned Off aka put into standby mode using the remote.
After confirming that the sound was mechanical, coming from the PSU, and not caused by a ground loop or DC in the AC line, I contacted MiniDSP support and asked them to send me a new PSU, which they did.
I installed the new one and it still makes a noise, but it is greatly reduced, like 90%. Before it was low-level but audible from across the room if my ear was anywhere near level with the SHD's location in my audio rack. Now I have to get about 1-1/2 feet away and bend down to align my ear with the SHD in order to hear it.
I noticed that the new PSU has the same design and layout as the old one - but there are at least a couple of different components, including the largest capacitor (forget the brands but one is black with silver stripe while one is brown with silver stripe). And I noticed that there are two exposed copper coils, right next to each other, and that on each PSU there appears to be a very thin layer of dried yellow stuff across the tops of them, that looks like some kind of glue or adhesive. The new PSU seems to have slightly more of this adhesive applied than the old one, though the difference looks like normal variation rather than a conscious change in the amount.
Here is a photo of the old one (the new one is in the SHD now and I didn't think to photograph it before closing up the unit), with the two coils circled in red.
I am convinced the sound is coil whine, not transformer vibration. My question is, would it be worth trying to apply some kind of glue more thoroughly around the exposed coils of the original PSU, to see if that addresses the problem?
Would anyone have recommendations for adhesive? I assume something not too thick and heavy, and perhaps something that dries with some elasticity in it so it won't crack over time or overly stress the coils. Would there be any electrical or thermal risk to doing this?
I'm open to trying with this PSU since it's now an extra and the new one works so much better. But I would not want to try this if putting the modified PSU back into the SHD to test it would pose any risk to the SHD itself.
Thanks!
Thanks!
