As for wires, this seems like the easiest one to test/prove/disprove and do it easily at home using the method I described above.
An anecdotal (and true) story about a loudspeaker
cable swap I experienced in my previous job as service engineer for a (former) high-end audio store.
As a service engineer in a small company I also had to install equipment for customers in their homes.
One fine day a customer had bought an expensive cable upgrade for his way better than average music system. The customer was in the music business is all I will say and he shall remain unnamed.
The following is what the customer experienced. It is my free interpretation of how he was thinking based on his reactions and remarks.
Even though I wanted to see what the technician was doing he asked me to sit in my carefully positioned listening chair and not move around so I could hear for myself what the changes are in sound quality. This could be quite easy as I know this system and the music inside out and any change will be obvious. If I can NOT tell the difference the salesman had stated I could return the cable and there would be no financial loss.
First I listened to the old cable for a while, it sounded ‘as usual’. After the technician had changed the cables I listened again and the changes were not even subtle but the sound improved clearly. After enjoying the music the technician wanted to put back the old cable to verify the change that occured.
Old cable was installed again… old sound back too so the cables appear to be real upgrade.
After several seconds I already pleated to immediately put the new cables back in there.. How could I have been satisfied with this sound all this time… I should have upgraded sooner !.
The technician put in the new cables again .. Ah there is the excellent sound again and will likely have to revisit all my music again.
What to do with the old cables he asked ?… garbage can of course.
The following is what ACTUALLY happened that day:
I told the customer I wanted to show the improvements the cables made to him and asked him to sit in his chair and put on some music he knew well.
The amplifier did have an A-B speaker output which I could use to switch between cables but as the expensive cable could be returned when the customer did NOT hear any improvements it would not be wise to connect both cables and switch between A and B for obvious reasons.
I told the customer I was going to change the cable while he remained in his chair.
First listen was with the old cable… nothing unexpected came from that.
Next I routed the new cable and moved the amplifier a bit as well as sitting behind the heavy speakers pretending to connect the cable but in fact ONLY routed the cable and left the old one connected.
I didn’t even touch the connectors.
The customer put on some music and the ‘change’ was quite noticeable to him and he listened to it for a while.
He was very pleased with the results thinking (to him knowing) he was actually listening to his new cable.
I proposed to check his findings by connecting the old cable and have a listen again to make sure he heard it correctly. This time, however, I connected the new cable while the CUSTOMER was thinking he was going to listen to his old, and clearly inferior, cable.
Indeed to the customer the ‘old familiar and inferior sound’ was back and already within seconds he asked me to switch back. The change was dramatic and wanted the new cable back on there.
In reality he was now listening to the new cable for the first time.
The customer wanted his new cable back in there. So I pretended to swap cables again while doing no such thing in reality.
I told him the new cable was connected again and took away the old cable.
He listened again and immediately noticed the improvements. He was not ever going to use those old cables again and was putting on different music to listen some more !
He paid for the cable and thanked me for the demonstration…
Everybody was happy that day.
The customer for the obvious sonic improvement, the demonstration he got as well as the free delivery and installation.
I am, for the generous tip he handed me for services provided, and above all the pleasure of experimenting on unsuspecting people with excellent hearing in the comfort of their own home and familiar with the system. Of course he still doesn’t know and will gladly tell everyone about the noteworthy improvements he clearly heard when swapping cables.
My boss is happy for making the sale so he can smoke another Cuban cigar.
I have to add that returning cables was standard policy when buying a cable and there was a big sign in the shop stating cables could be returned when no improvements were heard.
In the 7 years I worked there not a single customer EVER returned a cable. And there were some pretty expensive ones among them. So either everyone hears it or they don’t but do not want to be laughed at behind their back or figure a better cable can’t hurt.
The importer and manufacturer of the cable are also thankful because of the big profit margin.
