Well, how do you explain this:
I bought a brand new audioquest nrg x2, same cable different plug (fig 8) cable, for my tv and hifi. The cable I was using was the stock Samsung cable, which I upgraded, by putting an MK copper tough plug, which I 'defused'. Then I 'defused' my new Audioquest cable, and then swapped cables. I thought, oh no, it sounds too lean and cold. So then I just used it with my tv, and not going through my hifi, until at least 200 hours had elapsed. So when I was satisfied that there could be no 'needs burning in' issues, I put the tv on, going through my hifi, and as usual it sounded awesome, pissing all over all my friends av surround sound systems, which to me just blur and confuse the sound/music. So I had the Audioquest cable ready to plug in. I jumped up and as quickly as I could, unplugged the Samsung cable and plugged in the Audioquest cable, and jumped back onto my listening position, and I kid you not, there was a completely different presentation of the sound. I get goosebumps when something changes for the better. This cable, compared to my upgraded Samsung stock cable, was immediately satisfyingly and jaw droppingly better. Now you measured this cable, with a standard cable, and the results were very similar, I read the article. However, this was enough for you to completely reach the conclusion that you 'cannot recommend this cable'. Had you listened to it, after your results, I'm sure you would have realised that just because something looks very similar, when measured, doesn't always mean it will sound the same. Sure, as you know, audio cables are directional, and the decerning can tell the difference, but when it comes to powering a toaster, light bulb, etc etc, there's no notable difference, and I'm sure you'll agree on that, but when it comes to audio, the slightest thing can make a noticeable difference in the sound quality/presentation. I was disappointed that you didn't even 'listen' to the cable, after your measurements. So do you think that I have totally imagined the difference between the Audioquest cable and my upgraded Samsung cable? I suggest, in the nicest possible way, that you actually listen to both cables, when you are at your most relaxed state, and then you have done the most comprehensive test, possible. If you can't tell the difference, then I suggest that you could be in a situation that doesn't allow you to be fully discerning to judge this cable, or other cables properly, and indeed if you just measure things, with machinery and don't listen, to backup the test, then the question 'is it a complete and proper test' arises. Please listen to both cables.
Many thanks.
Russ.
