The show must go on. Indeed. You got that right.
@Thorsten Loesch
As the subject is often subjective here, I will write my little experience.
I'm not going to comment on numbers, initially they were very important.
I bought DACs from Gustard, SMSL and Oppo.
They are great devices, very detailed, but something is missing when listening to the music. It gets tiring after listening to it for a while.
When I bought an old Musical Fidelity DAC (I still managed to find a new one) the M1SDAC and then the iFi ones, when I heard it there was something magical for me.
It probably can't be measured, but it's what I really want to hear.
I was stuck on the idea of refuting the central point, when as far as I have been able to make out, there hasn’t been one.
Am I mistaking you for someone else, or are you the guy here who pops up regularly ASR thread reporting truly *outstanding* claims of hearing differences that by all boring old normie audio science thinking should be well nigh impossible? If you are that guy I would hardly be amazed that you'd find Mr. T a cool glass of water in the desert.The obvious Ad Hominem attacks against @Thorsten Loesch in this thread suggest a total lack of refutation against his central point. Speaks volumes...
Honestly this is a discussion of tests, measurements I don't take very seriously.I'm very sure it can be 'measured' using the very sorts of sensory analysis methods that Mr. Torsten selectively endorses.
Step one would see if it persists when you don't know you are listening to the MF DAC or one of the others.
It is but any audiophile claiming to hear "night and day difference" in sighted tests but in a controlled test, only gets 58 right should be downright embarrassed! When taking ABX tests, I strive for nearly 100% correct answer with vanishingly small p.Also notable, with 100 trials and 58 correct we have a lower than 1% risk of all statistical errors and can be mollified that g*ds of statistics have been suitably mollified.
I took that test and scored terribly-basically guessing. I'm impressed you scored that high. It makes me wonder how discriminating my hearing really is...It is but any audiophile claiming to hear "night and day difference" in sighted tests but in a controlled test, only gets 58 right should be downright embarrassed! When taking ABX tests, I strive for nearly 100% correct answer with vanishingly small p.
foo_abx 1.3.4 report
foobar2000 v1.3.2
2014/07/10 18:50:44
File A: C:\Users\Amir\Music\AIX AVS Test files\On_The_Street_Where_You_Live_A2.wav
File B: C:\Users\Amir\Music\AIX AVS Test files\On_The_Street_Where_You_Live_B2.wav
18:50:44 : Test started.
18:51:25 : 00/01 100.0%
18:51:38 : 01/02 75.0%
18:51:47 : 02/03 50.0%
18:51:55 : 03/04 31.3%
18:52:05 : 04/05 18.8%
18:52:21 : 05/06 10.9%
18:52:32 : 06/07 6.3%
18:52:43 : 07/08 3.5%
18:52:59 : 08/09 2.0%
18:53:10 : 09/10 1.1%
18:53:19 : 10/11 0.6%
18:53:23 : Test finished.
Total: 10/11 (0.6%)
And this was in a situation where the difference sighted was extremely small. If difference is large, the person should ace such tests so there is no need to perform any statistical analysis!
Now, if we had a random group of listeners with no claims in this regard, then sure, statistical analysis would play a strong role together with allowance of a more reasonable p value.
So, do you have such outcome for difference in fuses with speakers as you mentioned?
And I have heard the opposite even when being a few feet away from the speaker. The fact that in your one instance you can't hear something just means your speakers may be so insensitive that it is not an issue. It is not remotely evidence of inaudibly as plenty of people complain about noise at the tweeter. Indeed, almost all active studio monitors have hiss/noise near the tweeter. So much so that the major companies spec that dBSPL.BUT, FWIW, in my home system I can do that and there is silence, relative to the background noise in my relatively quiet house (quiet if the pool pump is not running).
When Chinese DAC makers release a product every few months to get a higher number on SINAD, is it good faith practice?
Many users associated this with better quality devices.
They have many reasons to release new DACs:When Chinese DAC makers release a product every few months to get a higher number on SINAD, is it good faith practice?
Have you also tried the test with a newer Foobar version? There are some important differences:foo_abx 1.3.4 report
If there's anything there, bring evidence. If there's not, it's your brain fart and really not up to anyone else to lift a finger about.Yes, or looked at another way, it can be a question that should be answered.
1) you do not see the result until you finish all trials, i.e. you see your probability score no sooner than after the last trial,
This one I don't mind and have published tests using it.2) the test gives you a checksum that might be verified by anyone else for validity.
It’s supposed to be a double blind test. The fact that you can know how well you did during the test seems like cheating.When differences shrink, they routinely become very specific to small section of the music, often one second or even less! To find these segments in a full 3+ minute track is impossible without feedback from the tool that you are on the right track. Our goal with blind tests should not be to make it hard to get to the truth. The fact that I found a segment and passed the ABX test is a good thing, not a bad thing.
Your supposed to do this on your own, just like you had to do your test all on your own. You claim audible differences, you’ll pick them out without any help. Worlds of differences should be no problem, right? Obviously, I’m not talking about you specifically . And yes, it will be harder when differences get smaller. But give it a few more rounds, and you’ll still figure it out.To impede my ability to do so goes against us being unbiased in finding whether these differences exist.
Why? The test is still double blind.It’s supposed to be a double blind test. The fact that you can know how well you did during the test seems like cheating.
As is logic. Physics is objective. Listening preferences subjective.Marketing is a hell of a thing.
Is it? Doesn’t knowing the results bias you? Because next time you know what to look for. You have been influenced by the test itself.Why? The test is still double blind.
Knowing what to look for is a feature, not a bug. You're still just using your ears, you just know what to listen for.Is it? Doesn’t knowing the results bias you? Because next time you know what to look for. You have been influenced by the test itself.
That is a constant in either case. Getting the results at end only serves to substantially slow me down compared to interim results.Is it? Doesn’t knowing the results bias you? Because next time you know what to look for. You have been influenced by the test itself.
