Hi,
> I agre with the entire post.
> But… there is some “boner de jur” with people lusting after the SINAD and SNR.
Sure. Some people buy car's by the numbers, others by looks, others by how they drive. I drive a Chopper bike in Captain America paintjob. Corners like a pig, but the looks I get from the chicks are worth it!
Some people buy gun's by numbers, others try, shoot and buy what get's them to hit the target reliably, quickly and without effort. A beat up Siam Mauser with 'scope and .357 special snub nose for self defence, heavily tactical air pistol for varmints here.
Some people buy impressive digital SLR's. I use an original 1930's pre-war Leitz Lense on an old Sony alpha 5000 body,
So some people pick Hifi for numbers, others for looks others for sound quality.
What is important is that as a consumer we know what we want/need and then put our money where the least money gets us the best result for our needs. The least money may still be a lot. But it will be value for money.
> At some point the distortion profile becomes important, which vanishes as the SINAD heads towards infinity.
There is more to that than just profile. Distortion needs to be actually pretty gross to be perceived, by modern (say 1970's HiFI) standards.
We can see that from the simple fact that few speakers or headphones are judged as being subjectively heavily distorted by listeners, despite the fact that it will be hard to find any speaker or headphone that exceeds 60dB SINAD at 105dB SPL.
Another thing, what is that SINAD fad? It is just THD & N. Can we just stick to established conventions? 60dB SINAD = 0.1% THD&N.
Yes, if we have all distortion below audibility, we will not have audible distortion. But is harmonic/intermodulation distortion, noise and frequency response all that may audibly alter our listening experience?
But let's take an example. The OPA2604 Op-Amp (external Class A biasing mandatory due to internal design) and the NE5532 (external Class A biasing optional but beneficial due to internal design) Op-Amp both have distortion and noise that under most conditions is reliably is inaudible. NE5532 actually has lower distortion and noise objectively speaking. Yet to me there are perceivable differences in sound quality, especially hard to quantify factors like emotional engagement. And wherever there is a difference there is a preference, in my case OPA2604.
Of course, we can take the NE5534 (single of 5532) with some interesting internal connections available and replace the input stage with high transconductance dual J-Fet's, increase the second stage current significantly and take the output from compensation pin with an external class A buffer with around 10mA Iq, now the "Franken 5534" will have more of the qualities that make the OPA2604 in my books preferable over NE5532, with lower noise and lower distortion than both originals.
It is tempting and east to jump to the conclusion that the lower distortion is the cause, but given that in all cases the harmonic distortion and noise is well below any audibility limit, it would seem that other, more subtle factors are at work here.
> It was seeing no chips on the board with 32 (or more) spider legs on it that had me wondering.
> And I did not recall seeing 32 bit DACS in the past.
> Routinely the sales are stored as 32bit float or integer, and most computers do not have native 24 bit registers, so 32 or 64 is a sensible container to hold 24 bit within.
> That chip is advertised as 24 bit, which is certainly enough.
> But a calling a 24bit DAC a 32bit DAC, is a bit of a marketing overbyte.
Maybe. But a DAC is not just a chip.
If a DAC (Device) accepts direct input via USB of a 32 Bit audio sample without requiring the source device to convert the 32 Bit Sample to 24 Bit, is that a 32 Bit DAC or not? If not, then what is? I can only accept the "194dB+ Dynamic Range" as alternative definition.
To me it is just one more number fetish. How many bit's are actually in a given music recording.
Say we use two Microphones with 20dB(A) noise floor to record a symphonic orchestra with 110dB peaks and 85dB average SPL for louder (tutti) passages and lowest actual musical passages at around 30dB (piano, solo).
In my experience this is about the greatest real world dynamics we get. Commonly it is necessary to "gain-ride" such a recording to make it listenable in domestic conditions, either live (like when we recorded to magnetic tape with 84dB dynamic range (-70dB noise floor and +14dB head room) in the 1980's. Nowadays you would use post production and high resolution (18 Bit or more) recordings to capture the original dynamics and do the "gain-riding compression" in post.
How many Bit's are required to represent this classical recording, uncompressed?
110dB - 20dB = 90dB = 15 Bit
So recording with a system that offers 18-19 Bit of real world resolution will make sure we miss nothing and capture everything. THen we can work on making it more suitable to home consumption in post.
Thor
