EDIT - Not sure if this belongs in 'general audio discussion' or '...analog audio'. Admins please move if it's in the wrong place!
Hello all!
I've been thinking for quite some time about whether or not there is any real advantage to low-output moving coils with nominal outputs in the region of 0.5mV compared to high-output types of 2mV or more, intended for moving-magnet inputs. The conventional audiophile wisdom regarding the latter type seems to be that it is an inferior system, making a compromise of more moving mass attached to the cantilever due to the higher number of turns required to produce a more substantial output voltage. I have some considerable scepticism towards this point of view, as for a start cartridge manufacturers who make models that feature low and high output versions specify identical frequency response and channel matching figures in the specification, which would not be the case if the moving mass (and hence tracking ability) was degraded by the addition of the extra windings. They're so very close to the pivot point/cantilever suspension that their momental inertia seems likely to be insignificant.
There do not appear to be any controlled measurements (using the same turntable and a preamplifier with at least similar frequency response/noise/distortion characteristics), or low vs. high output MC cartridges in the same model range. It would be most interesting to see if there is any difference beyond what could be expected in terms of device-to-device manufacturing tolerances, although perhaps a large sample size might be necessary to make a conclusively finding. This would probably be quite an expensive undertaking if the cartridges were not already in the possession of the tester
From a purely electronic perspective, the thermal noise generated by the increased coil resistance of high-output types actually gives a considerable advantage over the low-outputs when juxtaposed against their nominal output levels at 5mV/s. For instance, let's compare a few examples in the wild. As the coil resistance dominates the impedance of the cartridge in the audio band by at least an order of magnitude, a simple back-of-a-napkin resistive analysis will do:
| Cartridge | Nominal output (mV) | Coil resistance (Ohms) | Thermal noise (nV) 20Hz-22kHz | Flat SNR (dB) |
| Hana ML - low | 0.4 | 8 | 51 | 77.9 |
| Hana MH - high | 2 | 130 | 205 | 79.8 |
| Dynavector DV20-X2L - low | 0.3 | 5 | 40 | 77.5 |
| Dynavector DV20-X2H - high | 2.8 | 150 | 220 | 82.1 |
| Dynavector DV10X5 Mk2 LOW | 0.5 | 32 | 102 | 73.8 |
| Dynavector DV10X5 Mk2 - high | 2.8 | 150 | 220 | 82.1 |
If we apply RIAA equalisation to these figures, with a measurement bandwidth of 220Hz-22kHz (useful in real-world applications as it precludes flicker noise which is far less audible around 50Hz), we will see a further reduction from the flat figure of about 7.6dB thanks to the HF rolloff - meaning that the Dynavector cartridges are pushing a potential SNR of almost 90dB straight out of the gate. This is further improved by the fact that it's far easier to produce a front end that comes within 6dB of the theoretical maximum for a source resistance of 150 ohms than one of 5 ohms; the job can be done with a single IC such as the OPA1612, without the need for parallel discrete transistors and hybrid amplifier topologies.
Making a decent front end using discrete transistors for a very low source impedance can be quite a tricky business, as it's far more prone to detecting RFI than a simple op-amp input, not only due to the much higher gain, but also because the overall level of frequency compensation is increased to include all the extra devices in the loop which reduces the bootstrapping effect on the PN junction on the input where RF starts to rear up. This can lead to problems in setups where there are high levels of RFI - dodgy SMPS modules driving LED lighting, either operating without any EMC components or simply generating spurious transients as they approach failure, or ethernet-over-power can cause unwanted interjections. The conventional approach to dealing with this is to just use an IC input and maybe a stopper resistor, resulting in an SNR below 70dB after RIAA. The market has low expectations 'because the gain is so high', so manufacturers have been getting away with this for ages, but it's very poor engineering.
The setup itself is also far more prone to tiny currents here and there causing big problems with low-output cartridges, especially in relation to the floating ground drain/return of the cartridge. Setup hum and buzz might be below the noise floor for an output some 18dB higher. Making a low-noise input exacerbates the problem further: if the user couldn't hear these issues before, or simply compared them to the background hiss, the introduction of a phono-stage with a 10dB noise improvement might make these otherwise hidden problems noticeable which is not fun from a customer service perspective. For these reasons, I'm taking a little hiatus from making products for low-output MC (you can even find the schematic for the MC PRO attached to this post as a result).
If an OPA1612 with a 30 ohm series-feedback resistor (total noise 1.3nV/sqrtHz) was deployed as a front end for the Dynavector high-output cartridges, we would see a super post-RIAA SNR of 87.44dB, far better than the theoretical maximum of most low-output cartridges based on coil resistance alone. Even if we feed this into a moving magnet-optimised input based on an NE5534, we still get over 80dB. I'm fighting with everyone who contacts me now to go down this route if they've not already acquired a low-output MC!
Taking a reckless plunge into the murky depths of speculation, we could consider why the low-output types are lauded to be superior in the realm of audiophilia. Here are a few of my thoughts in this regard:
- High-output cartridges with a greater number of hand-windings are going to be more difficult to produce, incentivising manufacturers to promote the low-output type
- High-output cartridges are seen as a compromise, with some sort of trade-off for the increased level/ use with MM inputs; a good story about more coils and more moving mass
- Low-output cartridges are more specialist, requiring a dedicated pre-amplifier or step-up transformer, hence a more 'serious business' approach
- Low-output cartridges may be easier to produce with greater production tolerances, a big plus point for the exotic/high-end manufacturer in a shed somewhere
- The requirement for a step-up transformer allows the manufacturer to make an easy killing for a special sale, especially for users of valve equipment that can't impedance match the noise characteristics with a direct connection, hence more scope for promotion
So, all we really need now are some measurements in a controlled setup. Does anyone here have low and high output versions of the same model? If not, I'd better start saving up... It would be great to be able to have some proper hard evidence to present on this one.
Let me know what you think anyway - is there something that I might be missing here?
