Planning a loudspeaker measurement project to determine of there is any correlation between what we hear and how the loudspeaker measures.
http://www.puriteaudio.co.uk/blog
I'm still not sure what in-room measurements tell us. Is a perfectly flat frequency response a perfect speaker? If so, with DSP I can guarantee to give you a flat line, at least at a single point in space. Will it sound really good? Also, in an anechoic chamber I might be able to give you a flat line over a wider sweet spot. Ditto.Planning a loudspeaker measurement project to determine of there is any correlation between what we hear and how the loudspeaker measures.
Sounds like a plan, I will have to read up on exactly how, I just thought it might be interesting to see some plots from different loudspeakers where the room is a constant.
What about taking measurments in the garden?Just working on turning the dining room into an anechoic chamber as we speak, my wife has been frightfully understanding.
After just converting the dining room?What about taking measurments in the garden?
We need to see the off shed response measurmentsAfter just converting the dining room?
