- Thread Starter
- #61
1V is a bit low. Can you do some more tests?I just performed some measurements on the RME ADI-2 Pro fs (initial version) in loopback mode for the various methods:
RME ADI-2 Pro fs Loopback @4Vrms
Output and input +19dBu range
Balanced Y Cable on both outputs (Main out)
Balanced Y Cable on both inputs and M/S mode
SINAD = 112dB
RME ADI-2 Pro fs Loopback @2.5Vrms
Output and input +13dBu range
SINAD = 114dB
Input +13dBu range
Output Balanced Phone mode - Low gain (+13dBu)
Balanced cables of both channels to each input
(So NO output sum)
RME input in M/S mode
SINAD = 115dB !
I also received today my Linear Audio Autoranger II
RME ADI-2 Pro fs Loopback through Autoranger II @4Vrms
Autoranger in 1V output mode
RME Output +19dBu range @4Vrms
RME Input +4dBu range
Balanced Y Cable on both outputs (Main out) to Autoranger Balanced in
Balanced Y Cable from Autoranger Balanced out to both RME balanced inputs and RME input in M/S mode
SINAD = 110dB
or 2dB loss vs direct RME loopback
RME ADI-2 Pro fs Loopback through Autoranger II @2.5Vrms
RME Output +13dBu range @2.5Vrms
RME Input +13dBu range
SINAD = 110dB
All this means the loopback SINAD for the Autoranger II alone should run somewhere between 112dB and 123dB...
Should be good enough to perform basic measurements on speaker amps.
1) RME at 1V output without Autoranger
2) Then 1V to Autoranger (gain 0 dB)
3) Then hold Autoranger at 0 dB and set RME output level 4V and 2.5V
