LuvTheMusic
- Joined
- Jun 7, 2020
- Messages
- 112
- Likes
- 137
Yet another itch to change something:
My setup has an equipment rack in a corner of the room with biamped speakers some distance away. Currently, the two stereo amps are on the rack, which means running long-ish speaker cables: the longer is about 25', which includes a few small detours to stay along the base of a wall.
So I'm just wondering if I should consider placing the amps near the speakers. This would mean running long balanced interconnects from the rack to near the speakers, then using short speaker cables.
I seriously doubt that this would result in any noticeable change, but want to ask the more knowledgeable folks here if there might be some slight throetical improvement. BTW, the cables are of the ASR-approved "get the job done" variety: current balanced interconnects are Monoprice Stage Right, so new ones would be the same, just longer; speaker wire is 12-gauge "speaker wire" of unknown provenance (but it really is 12 gauge and it's not turning green.....). Amps are 300 w/channel, speakers are 92db efficiency, so no crazy loading or anything like that.
Part of the issue also involves cosmetics. Speaker wires are fairly ugly; slim black balanced cables might look a little better and definitely are more flexible, so could tuck in better along the base of the wall. (Now if they just made them in a color to match our carpeting, but alas, no such luck.)
